Author Topic: Wiseco pistons kits  (Read 3566 times)
Wiseco pistons kits
« on: May 14, 2008, 11:35:02 am »
can some one give me the Wisco piston number for the TM series please.
i found the MX one at 234P but whats the TM.  Found a chap doing a killer price on the Full kit under under a hungy so im asking for the rest of my bikes incase i need em.
Happpy to ask on any other wiseco numbers also if you provide them before end of week.
cheers Freaky    ;)
Doc
Re: Wiseco pistons kits
« Reply #1 on: May 14, 2008, 02:48:40 pm »
double ring #389 single ring #380 these are early kit numbers with L type rings and replacement rings aren't always available like the later C ringed kits. #234kit for the 250 yamaha's is also from the early/obsolete number list and could be L type rings also.
« Reply #2 on: May 17, 2008, 12:18:36 am »
i just put em back together, i got a 380 and a 234 and they are both double ring and normal rings ...  go figure :O)
« Reply #3 on: May 27, 2008, 11:43:54 am »
ok doc i just bought up a pile of 234, 380 and 389 and the 231 which i think is yam 360 in each P series numbers :O)
might as well be looking at them than for em .....  ;)
« Last Edit: May 27, 2008, 12:02:25 pm by Freakshow »
« Reply #4 on: May 28, 2008, 11:56:24 pm »
HEy doc that 389 kit with the single ring are they any good or are the rings on the shit side ?
Doc
« Reply #5 on: May 29, 2008, 06:09:49 am »
I can't see any reason why the single ring would be a problem Freaky. Only problem I was having is finding replacement dykes rings for my 125, after months of searching now that I have finally found some rings I don't have the whippy to buy em'..typical  ::)
