Author Topic: CHECK TIMING ON DT360A  (Read 2550 times)
« on: May 14, 2008, 08:22:38 am »
hi
i have a dt360a and i need to check the timing.the manual says use a dial indicator but i dont have one.is there any other way of checking this.i am replacing the key in the crank.i have a puller to get the mag off.
jim
Re: CHECK TIMING ON DT360A
« Reply #1 on: May 14, 2008, 12:21:22 pm »
Give me a ring Jim,I'll talk you through it
Offline pancho
« Reply #2 on: July 31, 2008, 05:07:02 pm »
g,day jim. you were asking about jet sizes for your 360 .i still havnt found  my book but i found another piece re-carby fitted to the rt2 model--- carby type-vm32sh mikuni i.d.mark-308e2....main jet-230.... needle jet 6dh3... clip pos 3... needle jet p-0.... cutaway3... pilot #45....starter jet #60... float level 21.4+-2.5mm ....also there is a rubber "o"ring on the bottom of the needle jet wich will make it run verry rich if not perfect  hope this may help cheers wally.
