Author Topic: RM125C on Evilbay $1600, Wonder if the aluminium swing arm would fit a 125A  (Read 2182 times)
Offline oldyzman
  • 250 two stroke!
Not stirring a very lumpy pot of Rhino poo are you..... ;)
« Last Edit: June 01, 2013, 10:28:46 pm by Tim754 »
It's a later production 'C' with a floating rear brake arm, so no  ;-)  LOL
TM BILL
Unless you weld on a brake lug to the arm, then whos to know  ;)
Whats the dif between B and C forks. Can one fit C forks to an A model and still be pre 78 legal?
Offline motomaniac
C forks have the extended air cap (and internals) thats all.
Montynut
'A' forks are in line so you would have to change the triple clamps as well I would think otherwise the geometry would be much different because of the 'C' leading axle, but you can not use the 'C' triples due to the legendary rubber mounts ;)
« Last Edit: June 01, 2013, 09:13:40 pm by Montynut »
