Author Topic: pe175 rm125 front brake cable  (Read 1908 times)
« on: May 27, 2013, 10:16:31 am »
Can someone tell me if the rm125n/t front brake cable is the same as the 80/81 Pe175 ?
Re: pe175 rm125 front brake cable
« Reply #1 on: May 27, 2013, 05:25:41 pm »
Answer is  No  ;D
Pe 175 is 25mm long overall, due to taller bars
Rm is 15 mm  shorter on the inner length also .
Paul ... but it will fit by just rotating your cam arm by one notch and re- drilling your brake blate ( just a fly shit )  to take the Rm cable adjuster.
Can post a pic if you want to compare  ;)
« Reply #2 on: May 27, 2013, 05:46:53 pm »
Thanks for the info Stu. Heaps of rm125 cables on ebay half the price of the pe ones, thought it was worth a try.  Cheers
