Author Topic: Not vmx  (Read 2211 times)
Offline hampster
Not vmx
« on: May 25, 2013, 11:28:16 am »
Hi all,
Can any body recommend someone that can rebuild or service a carburetor off a wr 450 05, it has a   intermitent problem that lets it sticks full open,
iam selling the bike and could not sell it with this problem.
Thank chris.
Offline smed
Re: Not vmx
« Reply #1 on: May 25, 2013, 06:55:40 pm »
Any good mechanic should be able to do the job,The Kehin FCR carb as fitted to that model has a 2 part slide that can sometimes break from backfiring,that usually results in a high idle, not full on though,could also be anywhere from throttle assembly to cables ;)
Re: Not vmx
« Reply #2 on: May 25, 2013, 09:24:59 pm »
Yes I was going to suggest checking the cables too, if they are starting to fray then they will bind inside the outer cable casing.
If you’re up for pulling the slide out of the carby then check that the cable moves freely then check the slide moves freely.
Offline hampster
Re: Not vmx
« Reply #3 on: May 26, 2013, 11:26:45 am »
Thanks,
The problem happened two years ago , after that I replaced the cables cleaned and checked all the carby checked if the cables did not bind after the tank went back on.
This problem happened again which caused a big off and a broken arm, after the bike was picked up it ran fine and was rode back 30 km with out a problem?? When it happened  two years ago it ran fine after that too.
I could not sell the bike with this problem so I will get a shop to double check in case I am missing some thing.
Thanks fo the feed back
Chris.
Re: Not vmx
« Reply #4 on: May 26, 2013, 06:16:43 pm »
Almost sounds like water on the slide if it happens occasionally & is fine afterwards, was water involved before the throttle stuck like a deep water crossing?
