Author Topic: KDX 175 brakes or lack of  (Read 2681 times)
Offline YUMASTEPSIDE
« on: May 21, 2013, 06:58:03 pm »
........anyone know the dark art of getting KDX front brakes to work ??........I'm getting tired of carrying a boat anchor around with me !
                                      Roger
TM BILL
Re: KDX 175 brakes or lack of
« Reply #1 on: May 21, 2013, 07:03:11 pm »
Do you have a new cable fitted ? i know it sounds daft but i fitted a brand new cable to mine and it was night and day . The old cable moved freely ( if you held it up  straight the inner would fall through the outer cable ) but a new motion pro cable made all the difference to braking performance .
« Reply #2 on: May 21, 2013, 07:34:49 pm »
Loosen off axle bolt, now apply brakes and hold on while tightening up axle.
This will centralise your drum and shoes.
Is your cable spongy .... if so replace it.
« Reply #3 on: May 21, 2013, 07:54:41 pm »
Cable flex is one cause , I always like Yamaha cables normally DT 175 are in stock in most dealers and fit 90% of vintage bikes. I also sometimes add heat shrink to parts of the cable that dont need to bend. Stiff as 15 year old surfing porn is best.
Offline topari
« Reply #4 on: May 21, 2013, 08:00:22 pm »
The trick years ago was to fit a PE175 front brake cable. Some modifications were required to the hub to fit the much thicker cable. At the time my brakes were better than the XR200 running around at the time. The xr200 had good brakes. Further you should check using chalk of blue die how much of the brake pads make contact with the hub. Sometimes it was less than 50 percent.
There is scope to have the brake working okay.
topari
1979 IT400F, 1984 kdx200
« Reply #5 on: May 21, 2013, 08:26:26 pm »
Thanks to all :).....my thoughts were the cable, so that might be first.
                                 Roger
