Author Topic: Frame earth  (Read 2812 times)
Offline CRTAD313
Frame earth
« on: May 21, 2013, 04:13:15 pm »
Have just powdercoated the frame of my cr125 , question is do i need to sand back where the engine mounts so the motor earths to the frame?
Montynut
Re: Frame earth
« Reply #1 on: May 21, 2013, 06:03:54 pm »
absolutely, also clean off the engine mount tabs
Offline OverTheHill
Re: Frame earth
« Reply #2 on: May 21, 2013, 08:24:32 pm »
another idea might be to run an earth wire from the motor cases up to the coil mount instead of having to remove a good paint jobby. Maybe there's reasons why that's not a good idea. I'll have another drink & think about it. Bottom line is, motor's gotta be done up super tight in the frame. Cheers.
Offline CRTAD313
Re: Frame earth
« Reply #3 on: July 18, 2013, 07:16:46 pm »
Have ground off the engine mount tabs , should i use a smear of grease or something similar to prevent rust or would this affect the earth?
