Author Topic: Suzuki RM125 1980 Shocks  (Read 3946 times)
Offline Toolboy
« on: May 12, 2013, 11:10:07 am »
Gday all,
Are the original Suzuki RM125 1980 Shocks able to be rebuilt with new seals??
If so, any where in SE Qld??
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline Tomas
Re: Suzuki RM125 1980 Shocks
« Reply #1 on: May 12, 2013, 03:01:22 pm »
1979-1980 Suzuki RM 125 shocks are sealed units. You can change oil and regas 1980 shocks.But you can not replace seals.
As long as your shocks are in good shape, no rusted shafts, good bushes etc, they can be modified to be rebuildable. you will need at least new seal heads to suit your shaft diameter  plus some machining to shock bodies to fit new seal heads. It is usualy internal thread(Works Shocks) or internal groove (Ohlins). RAD motorcycle in Qld should be able to help. Or if you can get suitable sealheds, 36mm OD and 12.5mm shaft diameter, than any good machine shop should be able to do all the machining for you.
If your shocks are in good shape it may be worth doing it. If not you are beter of geting YSS, or Works for $600 or Ohlins for $1000
hope it helps.
Offline Toolboy
« Reply #2 on: May 14, 2013, 08:17:56 am »
Gday Thomas,
Thanks for the good info, gives me a few options to look at.
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
