Author Topic: Who's fixing what ???.  (Read 13201 times)
Offline yzhilly
  • Melbourne
« on: May 10, 2008, 10:02:41 pm »
Well i just come in from the shed and i'm rooted . I pulled the CR80 engine down ,The big end is siezed , so i need to rebuild the crank and main bearings and reseal and that will do it . And i'm putting a YZ80S together . I just pulled the engine down and i have never seen a more forked one .The big end has about 12mm slop in it ,the needle out of the carb is bent and has been living in the reed cage ???.It would have been interesting to see this running but with all the YZ80 crap i've got i'm building up one good bike so that will be good . I've decided that i'm gonna update the YZ400E to 1981 suspension ,43mm front end and a New rear shock as i dont think a 465 will make me any faster .
« Last Edit: May 10, 2008, 10:06:49 pm by yzhilly »
Viper #436
Offline Graeme M
  • Administrator
  • Canberra, Australia
Re: Who's fixing what ???.
« Reply #1 on: May 10, 2008, 10:09:24 pm »
But it's fun isn't it? Nothing like a good garage session. I've just pulled the engine out of the TM125, gotta get the cylinder rebored and mod it to take the big carb etc, the RM125M is up on the stand to be pulled apart to the frame to clean the sand and crap from CD5 out of it, and the latest addition, the IT175G, is also going down to the frame for a full going over and clean up. And if I can get enthused tomorrow I'll clean and lube the 05 YZ - haven't touched it since the over the bars episode 8 weeks ago...
Offline yzhilly
  • Melbourne
« Reply #2 on: May 10, 2008, 10:13:02 pm »
Whats the  plan wth IT175  Geame
Viper #436
Offline yzhilly
  • Melbourne
« Reply #3 on: May 10, 2008, 11:02:42 pm »
What are ya up KB
Viper #436
Offline KB171
« Reply #4 on: May 10, 2008, 11:19:39 pm »
Fitted the pipe i got at CD5 to the125 and had a fair crack at a slab ,Hic :P
Offline DJRacing
  • YZ125X
« Reply #5 on: May 11, 2008, 07:23:49 am »
I need to do some work on the bikes before the Eno Classic in a couple of weeks. The YZ125J has been running rough and I think its the stator, I have a nos 1 on the way from usa, hopefully that will get her back to full power. The YZ125G still needs tuning, it isnt hitting hard, it just seem a bit flat all round. The YZ125E needs the exhaust pipe repaired and a general going over. The big job is the YZ125X, I need to strip down the motor and replace the mains and crank seals, a new rod kit, re-sleeve the barrel and a new piston kit. I replace all the seals of the bottom end because she leaks oil. The exhaust pipe is in 2 pieces so I have to get that fixed. The Noguchi 125 needs a new petrol tank cap and tap, and carb shut-off valve seat and a smaller pilot jet. Better get to it.
« Reply #6 on: May 11, 2008, 07:57:56 am »
How did that 80's shit song go?
"Never ending story" CR500 Ignition problems just for a change, but should be a goer this week when i get some parts from USA.
some small  mods to the trailer so i can make the bikes a bit more stable. when this is all done it time to pull the top end off the KTM. i also need to do a tidy up of the shed as i have no idea where things are are in so many locations and find myself buying things occassionally that i later find i already had (well at least stock levels remain)
Offline BETRIC
« Reply #7 on: May 11, 2008, 11:29:27 am »
HAVING WALTER FROM YSS MODERNIZE THE SHOCK ON THE RM250D, RESTORING A YZ80B, XR74 K4, BUILDING MY XR75 K1 AND MAGOO'S XR75K1 PIT BIKES, PLAYING WITH THE MX360 FRONT FORKS (YSS PD VALVES) AND CONVERTING THE MX FOR THE VINDURO AT ROCKLEY, ADDAPTING A YZ125 REAR BRAKE SET UP ON THE COOPER MX RACE BIKE AT LAST, FINDING TIME TO FINISH THE YAMAHA MX250B.
DELTEK, 72 MINI TRAIL, 73/4 XR75, 77/78 XR75, DG MONOSHOCK FRAME XR75, REDLINE FRAME XR75, PK RACING MONOSHOCK FRAME XR75, JWRP XR FRAME, SL70K1, 81 CR80RB, TY80A/B, YZ80A/B/D, GT50/80A, GTMX80A, 73 GTMX, GT1, COOPER MX, COOPER ENDURO,MX360A,MX250B,YZ125X MX100, 72 XL250, TC100,TL125, TY250C,IT250J
Offline paul
« Reply #8 on: May 11, 2008, 12:09:11 pm »
Quicksilver
« Reply #9 on: May 11, 2008, 12:39:20 pm »
Working on..
Honda.
MT250 getting up to rego standard.
CR250M almost collected everything needed.
XR75KO. Sweet runner, needs repaint and a few bits.
CR450RB needing only few more bits before I get started.
XL100 needs engine build.
MR50. Done as mini CR Elsinore silver tank.
Sorting oil feed problem with custom XR75.
Suzuki
RM125A getting new plastic's and good detailing.
TC120 in progress.
RM370. Collecting bits. Much to find.
Suzonda
Sorting out XL350 engine transplate into RM125 frame.
Yamaha
XT500. Has reco engine waiting to put back together.
XT250 building as dirt tracker.
« Last Edit: May 11, 2008, 12:54:11 pm by Quicksilver »
ted
« Reply #10 on: May 11, 2008, 12:43:47 pm »
Hilly PM sent
ted
« Reply #11 on: May 11, 2008, 02:34:10 pm »
Talk about teething problems.
First ride after resto
Throttle jams full open..fixed, no front brake...fixed
Second ride
Bike absolutely flies, suspension fabulous, brakes and throttle brilliant and so what does it do....loses F...en third gear. I had a shift fork repaired ( built up with nickel bronze ) and i suspect this has failed.
Have motor out on floor but am working interstate this week so it looks unlikely i will be racing at Glenbawn this week.Am going to ride my 530 in practice so i suppose all is not lost
Frustrated after all the money and time put into restoring it....grrr
Offline brent j
« Reply #12 on: May 11, 2008, 02:47:20 pm »
Suzuki TM125, starting to strip for parts assesment and rebuild.
Yamaha XT500 race bike, needs a weld on the swingarm and a cam bearing.
Yamaha XT500 second race bike, need too build it!
KTonda 200 and CRF230, need to ride them!
Several other XT's that just need time to think about.
And the bathroom..................the reason for all the hold ups. Don't ever consider renovations if you own bikes!
Offline crs-and-rms
  • heaven 23
« Reply #13 on: May 11, 2008, 02:51:01 pm »
rm 250 a still collecting bits
rm 250 b still collecting bits
rm 250 c2 still collecting bits
rm 250 t still collecting bits
rm 125 c still collecting bits
rm 125 n close to having all the bits i need
rm 125 t close to having all the bits i need
pe 250 n have all the bits and have started
pe 250 t still collecting bits but have started
cr 250 re still collecting bits but close to having them all
rgv 250 started and still collecting bits
i go from one to the next wish i could just stick to one but i find some parts for one and then do some on it ,then its back to one of the others  ;D ;D ;D
Offline caps 999
« Reply #14 on: May 11, 2008, 03:11:12 pm »
Yz100j to 175 racer currently stripped down
yz80j stripped down much work needed
yz250j still collectin bits (in the home strech)
atc90 looking for bits
MUGEN power
