Author Topic: Flat Slide Carby Needle Jet removal???  (Read 2143 times)
Offline Toolboy
« on: May 08, 2013, 02:33:09 pm »
Gday all,
This is the first tiome i have dismantled a Flat Slide carby and Im having problems with removing the needle jet.
My question....Is that a clip on top of the needle and you just pull it out using pointy pliers???
I have tried and it does not move far,, i dont to break it.
Any help appreciated
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline Stevo17
Re: Flat Slide Carby Needle Jet removal???
« Reply #1 on: May 08, 2013, 04:01:38 pm »
Once the main jet is taken off the needle jet should push out (back up through the slide opening).  Sometimes they can be a bit tight and need a little tap.  They are just the same as a round slide carb
« Reply #2 on: May 08, 2013, 05:55:54 pm »
Are you removing the 'needle' or 'needle jet', the needle is held in the slide with a 6mm hex plug that you 1/4 turn to undo.  The needle jet, as Steve says, should just tap out once the main jet is undone.
« Reply #3 on: May 08, 2013, 08:22:48 pm »
What make of carb?
Offline Toolboy
« Reply #4 on: May 08, 2013, 09:19:26 pm »
Thanks for the info guys got it, took a little while to get the plastic clip over the needle to come out...plenty wd40
Mikuni RM
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
