Author Topic: RM 125 S  (Read 9465 times)
RM 125 S
« on: May 07, 2013, 10:07:27 am »
I am about to jig a chamber for the RM 125 S soonish but have noticed that the barrel has 2 studs for a flange mount and the old pipe is the normal slip mount with springs.
Would this be a TS barrel or something or did the RM barrel have a bolt up flange on the barrel?
I assume the pipe would be the same fitment for the M & S models??
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: RM 125 S
« Reply #1 on: May 07, 2013, 10:27:30 am »
There was a gasket that goes between the pipe and barrel and a compression gasket that goes over the pipe that the bolt on flange compresses into the shaped recess on the front of the barrel to seal against the pipe (same as TS)
Ban BLACK rims NOW
Re: RM 125 S
« Reply #2 on: May 07, 2013, 11:14:09 am »
rm125m/s pipes interchange as use the same mounts etc,they will even fit on tm's and ts's even.are you going to use the same style of silencer the m/s had ???
TM BILL
Re: RM 125 S
« Reply #3 on: May 07, 2013, 12:03:26 pm »
What those blokes said Geoff  :) and yes an S pipe will fit a number of models , are you going for the traditional S stinger pipe and small muffler or will it be like your TM 125 pipe with built in muffler ?
Offline Nobby25
  • Could possibly fit other models?
Re: RM 125 S
« Reply #4 on: May 07, 2013, 12:14:04 pm »
Geoff, I would ask the same question because I think we would all like to see a traditional looking repro pipe and muffler.
Nob
TM125L RM250N TC125L RL250M PE175T RM80C RMX250T ATC70 YZ80B?
Offline huskibul
Re: RM 125 S
« Reply #5 on: May 07, 2013, 12:32:32 pm »
    I had an up-pipe built for my S back in 75' ! bike mechanic mike turner and i built it  after hours at the local bikeshop (Ranger Honda) he kept the original specs running it up the right side and using the stock silencer, looked cool, worked great and just finished off a great little bike ;)
Re: RM 125 S
« Reply #6 on: May 07, 2013, 01:00:51 pm »
Thanks guys, the pipe slips into the barrel but it seems loose in there.
From what I can gather from parts diagrams there should be some sort of gasket to make the pipe a tight fit into the barrel.
Is this how it works?
I will be making my normal style downpipe that has the muffler tube go all the way to the end cone.
I can also supply the chamber with just a stinger tube so that guys can fit their own short muffler for display etc but this isn’t practical for racing purposes.
Love it or hate it but we need to keep the noise down to help keep riding venues open so it needs a muffler at least 250mm long.
To fit such a long muffler onto the stinger tube puts too much weight onto the tube which will be sure to break it.
The originals only had short mufflers  (about100mm long) so there wasn’t much weight there but even so I think they used to break off too.
Haven’t actually built a TM 125 pipe yet Bill,
But if your thinking of my Elsinore pipe then yes it will be like that.
TM BILL
Re: RM 125 S
« Reply #7 on: May 07, 2013, 01:10:02 pm »
Sorry Geoff yep thats what i was thinking of and your TM 250 pipe  ::) on the upside an S pipe will be a bolt onto a TM 125 so you got that coverd to .
As CG said theres a tapered carbon gasket that slips over the header pipe and is compressed by the chrome manifold taht is retained on those 6mm studs ( if than makes sense  ??? )
Offline oldyzman
  • 250 two stroke!
Re: RM 125 S
« Reply #8 on: May 10, 2013, 08:13:48 pm »
GMC, do you have a jig for KX250A4 Down pipe for DirtTrack and is the mufler seperate.
Brett
Offline pmc57
Re: RM 125 S
« Reply #9 on: May 11, 2013, 08:32:46 pm »
Hi Geoff
I'll may be interested in one if you're going to start making them as a standard offering.
If I read right, are you offering two stinger options, long for anyone who wants to fit their short silencer or short for use with a 250mm silencer?
Do you have any indication at this stage of price?
Peter
Re: RM 125 S
« Reply #10 on: May 11, 2013, 09:39:45 pm »
Brett
No I haven't jigged for the A4 / A5 models yet.
I have built down pipes for the 74-76 KX 250's, not sure how compatable that would be for you though.
Re: RM 125 S
« Reply #11 on: May 11, 2013, 09:48:01 pm »
Hi Geoff
Peter
I have occasionally supplied chambers with just a stinger for those that are chasing a ‘look’
But most of my down pipes come with the muffler body welded on, this is a secure way of fitting them so that they will last the rigors of MX.
Elsinore 250, typical down pipe muffler style.
Re: RM 125 S
« Reply #12 on: May 13, 2013, 08:31:20 pm »
Geoff - were you any further with doing a YZB pipe?
thanks mate
Rossco
Re: RM 125 S
« Reply #13 on: May 16, 2013, 08:29:10 pm »
thanks mate
Rossco
Nothing in the planning at this stage
But just drop your bike over Rossco and I will sort it out for you ;D
Re: RM 125 S
« Reply #14 on: June 02, 2013, 09:56:01 pm »
