Author Topic: rm465 crank  (Read 1556 times)
Offline noisy toy
rm465 crank
« on: May 02, 2013, 08:28:52 pm »
Hi, I removed the clutch from my 465 to do crank seals and found the crank pinion nut loose. Lucky me I thought, saved it. Not so. I found that the key way section of the crank broke off as soon as I slid the gear off the crank. :( Does anyone know where I can get another crank, or at least a good rh half? Will any other cranks fit like older 400 or later 500?
thanks, shane.  :'(
