Author Topic: 1970 CR400 Clutch Problem  (Read 2608 times)
Offline Duane799
« on: April 27, 2013, 12:20:25 pm »
 Occasions when riding the 400 the Clutch Arm/Push Rod drops down and you lose the clutch. You give it push and it relocates and is good again. Does anyone know why it does this. It never use to do this before I rebuild the motor and the clutch. Any answers will be greatly appreciated as it is annoy when it happens.
Offline Snowy 76
Re: 1970 CR400 Clutch Problem
« Reply #1 on: April 27, 2013, 01:18:10 pm »
Sounds like the locating screw has been left out or is damaged  { screw behind ignition cover}
Couple of CR`s
Offline Duane799
« Reply #2 on: April 28, 2013, 08:36:41 pm »
Thanks for that will check it out.
