Author Topic: fork oil level  (Read 2388 times)
zman
fork oil level
« on: April 22, 2013, 04:13:22 pm »
 gday all  putting new fork seals in my 82rm 250  just wondering does any one know the oil level in them
thank you
Offline D project
Re: fork oil level
« Reply #1 on: April 22, 2013, 08:06:57 pm »
397cc or 178mm from the top, that's standard specs.
zman
Re: fork oil level
« Reply #2 on: April 22, 2013, 08:13:19 pm »
thanks d project id like to make them a bit harder so if i put in 450mls how much difference would that make
Offline D project
Re: fork oil level
« Reply #3 on: April 22, 2013, 08:18:28 pm »
Think you could try that. I had a set of 250 forks on my 125X. I found the standard oil level a bit soft. Usually the manual says to go in 10mm height changes. Not sure how much in volume you would be adding ???
Sure someone else will be able to help you out with what they run ;)
