Author Topic: YZ 400D fork oil capacity  (Read 2992 times)
Offline SimonC
« on: April 18, 2013, 01:09:27 pm »
Can anybody tell me the correct amount?
Many thanks
Simon
Re: YZ 400D fork oil capacity
« Reply #1 on: April 18, 2013, 10:23:04 pm »
As per owners manual 338cc  at 15 w   with forks fully bottomed measure from top should be 182.5mm. oil weight varies on conditions lighter for less heavier for more damping . Iain
Offline SimonC
« Reply #2 on: April 19, 2013, 10:39:59 am »
Thanks Iain
Offline crossedup2
  • Never enough shed time.....
« Reply #3 on: April 20, 2013, 11:02:42 pm »
Simon
The book says 182mm but you should run it up a bit higher. I have mine set at 135mm and it's a bit too firm. I'll soon drop it to 145mm which I think will work better. 15w oil.
Teknik go as high as 130mm from their webpage but I'd try the 145mm first. Good Luck!
Regards
Peter B
