Author Topic: Best paints for engines and exhausts  (Read 27556 times)
Offline PEZBerq
  • Brisbane
« on: August 15, 2007, 09:28:11 pm »
What paint brands can people recommend for use on engines.  I have stripped the paint off my Husky engine sidecovers and need something that will wont rub off the first time I ride it and also will take the heat.  Black gloss.
Same with the exhaust.  What paints have people found work best.
Thanks  Steve
Offline zorroz
Re: Best paints for engines and exhausts
« Reply #1 on: August 15, 2007, 09:49:29 pm »
I've found that paint from super cheap and the likes designed for brake calipers works great. I've painted a few motors with satin black brake heat paint and its stays on well even with petrol all over it. They also have gloss black. You can buy PJ1 engine paint from a bike shop but cost twice as much and you get less. Exhaust get a hell of alot hotter so I've found the pot belly black stays on the rest just burn off.
« Reply #2 on: August 19, 2007, 11:01:29 am »
VHT if you can afford it otherwise go for something cheap. ive used VHT lots and it works well for me. i like the 1500 degrees flat black for exhausts. i have the pipe sand blasted and now ive just started using a white Spies Hecker etch primer on the pipe first to give the back something good to stick to. ive heard of people using black paint ment for paining those pot belly fire things too.
oldscooler
« Reply #3 on: October 03, 2007, 02:25:15 pm »
DUPLI-COLOR black header paint, 1500deg...Its very durable and not too shiny. Covers well and makes your machine look like a million bucks!
EJ
Offline YZ250H
  • Back in QLD Baby !
« Reply #4 on: October 03, 2007, 02:44:17 pm »
Oldscool,
Where do you get Dupli colour and how much a can ??
Offline holeshot buddy
  • sunshine coast qld
« Reply #5 on: October 03, 2007, 09:04:43 pm »
to do it properly vht satin black for engines and flat for exhausts works great  ;)
it ran last time i started it  ;D
follow me to first turn
« Reply #6 on: October 03, 2007, 10:52:29 pm »
For my exhaust on my Maicos I use el Cheapo satin black from The Warehouse, Go Lo or any of the $2 shop emporiums. Cheap as shit and it works a treat.I started prepping my Maico for the Wagga Nats today and my pipe doesn't need any paint after a pretty torrid thrashing at the Coffs Nats. I've tried the expensive ones (VHT, PJ1) and in my humble opinion they're no better than the cheap stuff.
Offline Maicojames
« Reply #7 on: October 04, 2007, 11:24:55 am »
Here in US, it seems about the same paints are available. I never had to use it on my former Maico(unfinished pipe, sand cast engine), but tried the PJ1 on a buddy's 77 KTM. That crap is horrible-it is all binder with no pigment. I realize they are a cycle comapny and all, but it seems to me that they are thinning the hell out of the paint. It is even thinner than the lacquer I sprayed on cars in 1980s.-and that was thinned at 150%. Save the frustration and use Dupli-Color or VHT for engines, I can't say for exhausts.
Life is suddenly very Monaro
« Reply #8 on: October 04, 2007, 08:45:14 pm »
also give HPC coatings a go. it costs more than a can of paint but it lasts for ever and wont burn off. ive seen harleys done with it and there is no blueing,or changes in colour like normal chrome. you can get it in black too. ive considered doing it but at the the moment im happy to repaint pipes once a yr with 1500 deg VHT flameproof coating
picklediddy
« Reply #9 on: October 17, 2007, 04:43:30 pm »
My Local Powdercoater Roberto @ E.L Lewis in Brissy
Has developed a temp resistant Powdercoat for pipes
My 83 cr is in there now
Might get him to laser etch the engine as well
Will have pics soon
« Reply #10 on: October 17, 2007, 04:47:16 pm »
what is laser etching ?
090
« Reply #11 on: October 17, 2007, 08:03:57 pm »
With  HPC the chap in Queensland who does it will only do a new pipe as the carbon deposits etc contaminate the process
Offline TonyB
« Reply #12 on: October 18, 2007, 09:57:46 am »
I have heard people mentioning using clear paint on exhausts, I have just bought a retro rocket pipe which looks awsome unpainted but it won't stay that way for long, can anyone tell me if they have used clear and if so what was it??
'Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways,totally worn out, shouting,  ' Holy sh!t... What a Ride!! ' '
« Reply #13 on: October 18, 2007, 08:51:29 pm »
those trick unpainted pipes have always had me concerned about rusting but i believe the trick is to coat/rub them down with oil and dont leave water on them (dry them off after washing)
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #14 on: October 19, 2007, 11:04:07 am »
DON'T use clear paint on exhausts have a look at what the clear paint looks like after a few rides
http://w2.bikepics.com/pics/2006%5C12%5C29%5Cbikepics-758319-full.jpg
Ban BLACK rims NOW
