Author Topic: Advice needed  (Read 2282 times)
Offline maxi81
Advice needed
« on: April 13, 2013, 05:40:48 pm »
I have just fitted a new mikuni carburetor to my RM 400 and when I twist the throttle I have about half the amount of rotation then previous I had before. I noticed where the throttle cable goes into the carby slide is on the edge not in the middle like the stock slide. Would that make any difference?? Otherwise maybe the stock accelerator cable is not suitable  ???
Offline mick25
  • Hunter valley NSW
Re: Advice needed
« Reply #1 on: April 13, 2013, 06:02:17 pm »
Is the slide droping all the way down and hitting the idle screw , if not you need more cable free play.    or your cable maybe to short.
the cable should be in the centre of the slide aswell.
Re: Advice needed
« Reply #2 on: April 13, 2013, 06:10:45 pm »
Exactly. If the cable hooked into the centre before then there must be a scew on extension to the slide on the stock carby compared to the cable attatching directly to the slide on the new carby, therefor you need a longer inner cable.
Offline ARN
Re: Advice needed
« Reply #3 on: April 16, 2013, 05:09:03 pm »
i had this problem when trying different slides ,to fix it i tapped the 2 holes to use the existing cable mount. they are 4mm
cheers arno
