Author Topic: Maico 84 shock  (Read 5337 times)
YSS
Maico 84 shock
« on: May 07, 2008, 07:32:11 pm »
Finally we finished the replacement shock for the Maico 84 . Alot of people used to brake the original 14 mm shafts , so we made it with a high tensile 16 mm shaft . Instead of the original hose and reservoir set up , we opted for a compact piggyback set up. The rebound adjuster has 60 clicks , lowspeed comp has 20 clicks and high speed has 20 clicks of adjustment . That should give a huge window for any rider.
Those shocks will be available from Mainly Maico exclusive.
Re: Maico 84 shock
« Reply #1 on: May 08, 2008, 07:20:51 pm »
Walter,
Your'e killing me, I'm thinking of getting mine back just to fit that beauty.
YSS
Re: Maico 84 shock
« Reply #2 on: May 08, 2008, 07:46:04 pm »
Get one anyway , that unit should also look good hanging on the wall  :D :D.  ( just joking )
« Last Edit: May 08, 2008, 08:10:38 pm by YSS »
Offline TonyB
Re: Maico 84 shock
« Reply #3 on: May 11, 2008, 07:07:00 pm »
Walter that thing looks like it might fit my 83 495 ktm?? whats the travel and eye to eye measurement etc?
'Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways,totally worn out, shouting,  ' Holy sh!t... What a Ride!! ' '
YSS
Re: Maico 84 shock
« Reply #4 on: May 11, 2008, 09:07:39 pm »
I only have the specs for 86 . Give me what you require and I let you know . Cheers Walter
YSS
Re: Maico 84 shock
« Reply #5 on: December 28, 2008, 09:52:10 pm »
Tony , I now have the specs for the KTM 82-38 also
Offline Mike S
Re: Maico 84 shock
« Reply #6 on: January 01, 2009, 02:06:00 pm »
Hi guys.. A freind of mine has a 250 Maico water cooled registered enduro bike 84 model..
Any idea on what price range they go for??
Mike
maicoman
Re: Maico 84 shock
« Reply #7 on: January 05, 2009, 02:04:59 pm »
Walter do you have a price for the unit. I had the shock in my 84 Maico rebuild several years ago by Sigra at Penrith and they did a bad job. They cut off the original reservoir hose and fitted a hard plastic hose. 3 months later the shock started leaking. Your shock looks very similar to the piggyback Ohlins I have in my 85 M-Star. Possibly may fit? :)
YSS
Re: Maico 84 shock
« Reply #8 on: January 05, 2009, 02:52:01 pm »
That shock as per pic would cost $ 1750.00  , but if you have an other brand that we could modify to suit , the cost would be considerable less . I would have to see it to quote.
