Author Topic: How to make up air valve lines?  (Read 1534 times)
« on: April 08, 2013, 10:56:24 am »
Hey Guy's,
Just wondering if anyone has idea's on how to make up some air lines that will connect to the airvalves on my forks?
Firstly I want to join the valves together in a T piece and then maybe add a sub-tank to hold extra volume so the pressure rise is not so great as the forks compress.
Just wondering if fittings are made that connect and where I might get them from?
Re: How to make up air valve lines?
« Reply #1 on: April 08, 2013, 11:04:51 am »
Try Pirtec or one of the other pneumantic and hydraulic line companies.
« Last Edit: April 08, 2013, 11:13:03 am by firko »
« Reply #2 on: April 10, 2013, 10:12:56 pm »
Not sure what kind of pressure your talking, but the first thing that comes to mind are some hoses from a kmart bicycle pump that would screw directly to your fork valves, then get a short piece of high pressure pvc pipe and a couple of end caps that's tough enough to tap a thread into. The other end of the pump hose would screw into either end of the canister. It's probably not a long term fix, but cheap to play around with until you get the set up you like.
