Author Topic: RM125C piston  (Read 10888 times)
Offline pmc57
Re: RM125C piston
« Reply #15 on: May 10, 2008, 08:03:47 pm »
Lozza, We ran the 125C at Nudgee today with the correct jetting and it ran great, It seems a mixture of the incorrect pilot, needle and slide cut-away we enough to stuff things well and truely.
Thanks to all for their very constructive input.
pmc57
Re: RM125C piston
« Reply #16 on: May 10, 2008, 10:50:47 pm »
Ran OK with the holes out of alignment?
No no big fan of the power reed set up Doc it's way inferior to a full reed set up, but yes better than a piston port.Feel it's more an $$ thing that kept it going for so long.
Offline PERM250
Re: RM125C piston
« Reply #17 on: May 10, 2008, 11:17:30 pm »
hey doc the c went great finaly got it on the track  give you a ride on it at the next meet  .it was a little scary.ed
Doc
Re: RM125C piston
« Reply #18 on: May 11, 2008, 06:08:27 am »
Ed, yeah I was to be up there myself as I'm really hanging for a ride but work once again dictated what I did with my life. I hate that!  >:( glad to hear she's all go. I was figuring it being in the carb as I've had much the same happen with my TM when I first built it and didn't have the correct jetting or correct carb for that matter. I feel the out of alignment relief holes in the piston will still work ok even if off centre to the bridge. The holes will effectively still relieve the hot spot on the piston and it will add a little lube to the cylinder wal even if not in the correct place, in my view it will work but obviously not as effectively. At 56mm bore you could buy a std TM125/CR125 piston, drill the holes in the absolute correct spot and run with that (cheap cheap!) but you must run it as a single ring piston by omitting the lower ring that would/will otherwise snag or hang up on the ports. ;)
Loz, again you're talking about outright HP figures. This is where we differ, I talk of good power being had from the stock motors with minor tweaking and you talk of full blown race engines. Suzuki had enough faith in the system to start using it in another guise on production bikes way back in '71,(enter the rotary valve case reeded induction) Eventually the half piston port half reed version found it's way to 'all' RM's, PE's, TS's, TF's 50cc thru 400cc from '78 to '81 and none of these bikes were down on power at the time comparatively speaking. I still think there is more gain to be had setting up the chassis properly but each to their own of course ;) I like the case inducted RM styled motors, I like the way they deliver the power and I love the reliability that came with them..but then, maybe I am just a little biased  :P
« Last Edit: May 11, 2008, 06:16:00 am by Doc »
RMJJ
Re: RM125C piston
« Reply #19 on: May 12, 2008, 08:08:40 am »
I used to race a 125C back in 79.
Case reeds were the best then and Suzi went back to them in 84 after trying full reed in 82 83.
Casereeds are much better in my opinion.
The "power reed" name was given because the standard reeds were manufacture by boyesen and licensed to suzi. In other words all new suzi's came with boyesen reeds standard.
Back to that piston. Have you tried contacting Crooks suzuki in the UK. They will more than likely have a correct standard fit one although I'm not sure if suzi went as far as 2mm.
