Author Topic: 38mm yam fork dis assembly  (Read 1975 times)
Offline Rookie#1
  • JUST SHUDDUP AND RIDE IT!!!
« on: April 04, 2013, 07:31:48 pm »
G'day gents, what size nut is needed on the end of a bar to slide down 38mm yam forks for dis assembly??
Offline mick25
  • Hunter valley NSW
Re: 38mm yam fork dis assembly
« Reply #1 on: April 04, 2013, 07:48:54 pm »
On the yz 250 , 400 1977 and some other yamaha models
they have an external piece on top of the damp rod, not the internal sort.(where you can weld a large nut to a square rod )
I made a rod end I think it was 10mm by 15mm but will have to check in the shed for spot on measure
Its a small end on the damp rod so you have to get it spot on so it wont spin.
or try a rattle gun , but some times they dont work aswell.
« Reply #2 on: April 04, 2013, 08:14:57 pm »
Rattle gun + round end of broom handle usually works
Offline Viper666
    • Ballarat Rovers MCC
« Reply #3 on: April 04, 2013, 10:25:35 pm »
Cut the end off a 10mm allen key so as to fit into a 10mm socket & put them on a rattle gun. Leave the fork assembled, turn upside down & press down hard. Something through the axle hole works well as does a mate who can do the pressing. Put the rattle gun on the 10mm allen bolt & give it to it.
Offline Yamahaha
  • Melbourne Vic
« Reply #4 on: April 04, 2013, 11:51:34 pm »
I have two 175Gs, one of them needed a 19mm head, the other a 22. Go figure they are 3 months apart in build dates. My 79 400 is a 24mm head. I made up long rods to suit all of them with bolts welded in one end of tube and a 1/2 in drive in the other. All are 38mm fork. However still use a rattle gun on the Allen key it is much easier
YZ 250 modern, YZ 125G, YZ 125E, IT 400D, IT 175G x 2, YZ 400F CR250re,  2012 yz450fse Service Honda CR500AF.   Viper #73
