Author Topic: KX250 1976 - standard jetting specs?  (Read 3372 times)
Offline Canam370
« on: April 01, 2013, 04:48:17 pm »
Anyone have the correct standard jetting specs for this model?
Re: KX250 1976 - standard jetting specs?
« Reply #1 on: April 01, 2013, 05:13:37 pm »
main jet     142.5R
Air jet        0.5
Pilot  jet     45
neddle jet   P-O        clip centre
jet neddle   6DH2-4
air screw     1 turn out
fuel level    38mm  +/-  1mm
Hope this helps
Offline Canam370
« Reply #2 on: April 01, 2013, 08:02:56 pm »
Thanks for that, helps a heap. :)  Looks like the jetting is OK. I have to look into the running. Over 1/4-1/3 throttle the thing dies like the slide needle has dropped into the needle jet! OK, now the fun starts - where's the needle hiding in the haystack of possibilities? Another project (but a good one!), sigh...... :D
« Reply #3 on: April 01, 2013, 08:17:11 pm »
What sprocket ratio are you running ??? I'm finding  13 -48 =3.69  is a bit tall and leaning toward 13 - 50 = 3.85.
Offline Canam370
« Reply #4 on: April 01, 2013, 08:30:21 pm »
Sorry, but I haven't ridden it faster than the pilot jet will allow! Looking forward to be able to give you my opinion at some point! ;D
« Reply #5 on: April 01, 2013, 08:40:00 pm »
Hold on tight with both hands then  ;) as they pull strong down low.
Offline oldyzman
  • 250 two stroke!
« Reply #6 on: April 01, 2013, 08:43:37 pm »
OLD fart, do you actually use the air correction jet at 0.5. as i have heard some people run without it at all in 250's and over??
Brett
211kawasaki
« Reply #7 on: June 26, 2013, 09:12:17 pm »
throw that standard 34mm crap carb away and get a proper Mikuni 36mm, your problems will be solved.
DT
