Author Topic: Sleeve turning in barrel  (Read 2246 times)
Offline mitch75
  • Newcastle NSW
« on: March 27, 2013, 07:44:45 pm »
My sons 1984 KX60 finally refused to go.
Being down on compression it's time for a top end rebuild.
After closer inspection of the barrel I noticed the sleeve has turned in the barrel blocking ports off.
This explains why it has been struggling into powerband.
How to fix this?
« Last Edit: April 03, 2013, 12:19:58 pm by mitch75 »
Yamaha DT360a DT250b DT100c YZ400D WR250ZG.
Offline kim80y
Re: Sleeve turning in barrel
« Reply #1 on: March 27, 2013, 08:48:58 pm »
You can heat it up in your BBQ and turn it back to the applicable point, then let it cool down naturally.
You will prob have to bore or at least hone it after though, even if it is freshly bored, just to be sure it is still the right shape and not out of round.
I only know this as mine moved up when baking paint!!!!
Kim
Offline matcho mick
    • Moto Tumbi
« Reply #2 on: March 27, 2013, 11:51:09 pm »
when you "weberit",make sure you support the actual barrell from underneath,metal strip blocks,allowing the sleeve to drop down through,also good idea when cooling is to place a heavish object (large socket?)on the actual sleeve "top hat" part to make sure it sits still,& does not creep up/out the top,typically was chrome bore originally converted to reborable iron,maybe wickin loctite to stabilize afterwards when it's cooled ,hth, :P
ps just thinking if the sleeves capable of moving in the barrel sideways methinks theres certainly not enough interference fit so the loctite would be the go
« Last Edit: March 27, 2013, 11:56:17 pm by matcho mick »
Offline mitch75
  • Newcastle NSW
« Reply #3 on: April 03, 2013, 12:46:29 pm »
After half a hour of i'll be buggered I pushed the sleeve out by hand  ???.
Have taken it to the motor reconditioner. He is going to put a pin in to stop it turning.
The head will hold it down.
« Last Edit: April 03, 2013, 12:57:26 pm by mitch75 »
