Author Topic: How to remove needle jet from carb  (Read 2599 times)
Offline maxi81
« on: March 23, 2013, 01:47:36 pm »
Can anyone give me some tips on how to remove the needle jet from my carb? I don't want to break anything??
Offline head
Re: How to remove needle jet from carb
« Reply #1 on: March 23, 2013, 01:50:44 pm »
Take the main jet out, remove slide, then jest tap it out from mainjet end. Small pin punch or screwdriver. Should come out fairly easy.
« Reply #2 on: March 23, 2013, 02:56:58 pm »
Put a rag in the slide area so when in finaly falls out it does not damage the cut away area.
Be extra careful  making  sure you don't damage the main jet .
Offline maxi81
« Reply #3 on: March 23, 2013, 03:52:39 pm »
Thanks guys, needle jet has now been removed.
Just another question. I've got a new minuki carburetor to put on the bike. Do I need to change the float arm height?? According to the carb info it is set at 18mm, in the manual for the bike it says 13.9mm.
« Reply #4 on: March 23, 2013, 03:57:54 pm »
Come on Maxi, I'm sure we covered all this in that paving unit  ;)
