Author Topic: dt200r  (Read 1143 times)
Offline twinrock
dt200r
« on: March 14, 2013, 02:16:32 pm »
i have a 88 dt200r i bought this and took the ignition off it for my other dt200 so it is missing stator,cdi pv servo motor.. every thing else is there and original bike ran fine very smooth but had a high idle situation i put in new crank seals as well as a water pump seal but didnt chase the problem any futher.
bike is as u would expect a 40tho road trail to be ..used but not flogged
had good tires tank is straight rads and pipe perfect good seat forks good too
.$600 will part out if needed.. thanks 0406726252
