Author Topic: MC5 Swing arm pivot  (Read 9441 times)
Offline Gippslander
Re: MC5 Swing arm pivot
« Reply #15 on: March 18, 2013, 12:04:41 pm »
Am planning to do this job in the next month or so, where do you guys buy the bearings from?
Are the four o-rings a standard size or a special KTM part?
Bike is a 74.5 250 MX, the plugs that allow you to fill with thick oil have grease nipples fitted, was that a common way to lube, should I go back to oil after the new bearings are fitted?
Offline ozktm
« Reply #16 on: March 18, 2013, 01:44:04 pm »
A full kit from Andre' Horvath.
Comes with new bushing for bearings to run on, o-ring/bearings and end nuts.
Regards,
Adrian Goold #101
Offline supermotomc
  • SWM ktm, dealer mechanic 1977-1995
« Reply #17 on: March 18, 2013, 05:23:10 pm »
er whats 99 for lika fill it up regularly maybe even hole or slot   the central sleeve so that it dosnt dry out but to tell you the truth we used to pull the s/arm off after ever two day ktm oring of that era didn't seem to do a good job
