Author Topic: rl250 ts250 magneto cover  (Read 2084 times)
« on: March 09, 2013, 08:05:51 pm »
I'm after a magneto side engine cover, not the inspection plate, for a 75 rl250. I think the ts250 of the same era will work
Re: rl250 ts250 magneto cover
« Reply #1 on: March 11, 2013, 08:29:59 pm »
Anyone?
saint
« Reply #2 on: March 11, 2013, 09:02:42 pm »
Paul,
Part No 11351-38000
RL 250 L/M
TS250 R-M (1971-75)
There would have to be lots of TS engines out there?
« Reply #3 on: March 11, 2013, 09:06:20 pm »
Paul,
Part No 11351-38000
RL 250 L/M
TS250 R-M (1971-75)
You'd think so wouldn't you?
Thanks for the info
saint
« Reply #4 on: March 11, 2013, 09:19:26 pm »
One on Ebay US atm, but needs repair.
Also Maleny swap is on this Sunday.
« Last Edit: March 11, 2013, 09:23:46 pm by saint »
Offline Doc
« Reply #5 on: March 11, 2013, 09:52:59 pm »
I'll have a look if I have a useable cover Paul but from memory I only have one that isn't broken and it's on my RL.
While there are many TS250's out there it is 'very common' to have this cover crack or break the lower mounting point when the chain comes adrift and wraps up on the front sprocket. Unfortunately when the lower mount is broken it allows the cover to flex outwards as the clutch worm pushes the rod making the clutch inoperable. Early TM250 are the same cover also albeit black not silver. Another fix is to use a later TM250 or '76 TS250 setup which has a pinion type clutch release on the clutch cover. Obviously you'd need the matching pressure plate as well but it is an option.
« Reply #6 on: March 11, 2013, 10:02:54 pm »
Ok, thanks Chris, there's 3 on ebay at the moment and they're all broken. That explains why ;)
Offline Doc
« Reply #7 on: March 11, 2013, 10:13:42 pm »
Just had a sniff around and  don't have any sorry. Also just looked on fleabay US. 1 is a '69/70 cover and the item linked below is not TS250 but TS185 so it's useless also.
http://www.ebay.com.au/itm/160890873600?ru=http%3A%2F%2Fwww.ebay.com.au%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D160890873600%26_rdc%3D1
Will phone a friend tomorrow who may have one ;)
« Reply #8 on: March 11, 2013, 11:51:20 pm »
Cool, thanks mate
« Reply #9 on: March 12, 2013, 12:36:37 pm »
That's the setup my rl had, explains why
« Reply #10 on: March 14, 2013, 09:36:31 pm »
Bruce Bolton has an RL, dont know if its worth calling Boltons motorcycles and seeing if he has any spares?
(long shot)
« Reply #11 on: March 15, 2013, 06:02:48 am »
(long shot)
