Author Topic: Maico 440 piston in RM 400  (Read 5128 times)
Offline rmbing68
« on: March 05, 2013, 05:38:03 am »
Hey guys, I'm installing a Maico 440 piston in my '79 RM 400. Ran into one problem, the side to side play on the piston end of the rod. I have .160" side to side play. My engine builder said we need shims/thrust washers here, to limit the side to side play. What did you guys do to eliminate this? Any help would be appreciated.
I'm looking at 18mm id x 28-30mm od x 1.5mm thick, thanks.
Offline Toolboy
Re: Maico 440 piston in RM 400
« Reply #1 on: March 05, 2013, 08:28:55 am »
I fitted Wiseco 440 piston to my RM400 and did not have this issue.
I don't have the part No with me but can get in a few days
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline rmbing68
« Reply #2 on: March 05, 2013, 08:54:11 am »
Tim, thanks for the info. I'm using a Wossner piston.
Ralph
« Reply #3 on: March 05, 2013, 09:01:09 am »
A little bit of side play doesn't matter the piston can't go anywhere, the tight clearance at the big end keeps everything in line
Offline DR500
« Reply #4 on: March 05, 2013, 10:35:01 am »
You have thrust washers on the big end , which stop side to side movement of rod.Piston small ends need the clearance
« Reply #5 on: March 05, 2013, 11:00:30 am »
I may be asking a dumb question but why use a Maico piston? Are Suzuki pistons unavailable or is it an oversize thing?.........Just curious as Maico Mahle forged pistons are heavy old buggers, I'd assume a fair bit heavier than the Suzuki item which would possibly throw the balance factor out a tad.
Offline Mutch
« Reply #6 on: March 05, 2013, 12:59:45 pm »
Rick Horvat in the states does a 1mm os for the RM400
[email protected]
bikebuzzard
« Reply #7 on: July 12, 2013, 01:11:37 pm »
When installing the Maico pistons in the RM400 - be sure to use the MAICO wrist pin bearing....it is wider than the Suzuki bearing and that piston was made for the Maico bearing anyway!....( all the other measurements are the same as the Original Suzuki Bearing )
