Author Topic: Do All PE's Rattle?  (Read 6797 times)
Tony T
Do All PE's Rattle?
« on: February 21, 2013, 08:52:45 pm »
I've never ridden a PE for any length of time before and thought my recently acquired PE250C was a bit rattly in the top end, so I pulled the barrel, measured it up and fitted a new piston kit.
Went for a spin today and it sounds much the same.  ???
Might do a video tomorrow, but had anyone got any thoughts on this?
Maybe I just worry too much.........  ::)
« Last Edit: February 21, 2013, 09:21:19 pm by Tony T »
Offline mustanggrahame
Re: Do All PE's Rattle?
« Reply #1 on: February 21, 2013, 09:01:12 pm »
Don't worry about it Tony. All air cooled motors make a fair racket if you listen.
Is it a good thing?
Cheers, Grahame
Simo63
« Reply #2 on: February 21, 2013, 09:01:23 pm »
Has it got the rubber blocks between the cylinder fins still Tony?
They are a rattly piece of gear if you ask me but then, so are most air cooled motors.  As a matter of interest what was the piston to bore clearance?
Tony T
« Reply #3 on: February 21, 2013, 09:20:43 pm »
Thanks fellas. It has been a while since I've ridden an aircooled 2 stroke seriously.
I also listened to a few on You tube and they didn't sound any different to mine. I'm confident now that I am just a worry-wart.
My mechanic from when I raced seriously was always having a go at me about that......  ::)
I didn't measure the piston cos it is new, Simo. But the bore measured a max. of 67.030 and the service limit is 67.070, so I figured that was fine.
The best solution might be ear plugs!  :D
« Last Edit: February 21, 2013, 09:51:44 pm by Tony T »
Curly3
« Reply #4 on: February 21, 2013, 09:24:19 pm »
I thought all 2 strokes rattled, but what would a 4 stroke man know.
If you've dealt with piston clearence then maybe the rattle is vertical, eg bigend.
Offline the stig
« Reply #5 on: February 21, 2013, 09:26:06 pm »
       It's When they Stop Rattling  ..... you start to worry Tony..
       The Stig
« Reply #6 on: February 21, 2013, 09:35:47 pm »
You used pre- mix ......yeah. Just checking  ;D
Offline Canam370
« Reply #7 on: February 21, 2013, 09:41:58 pm »
Don't try to scare him....it could just be the small end! You want to hear rattles - listen to a big fin Sachs engine 8)
The Stigs right too.
Simo63
« Reply #8 on: February 21, 2013, 10:17:09 pm »
Don't try to scare him....it could just be the small end! You want to hear rattles - listen to a big fin Sachs engine when you hit one of the numerous false neutrals and grab a fist full of throttle 8)
Fixed for you  ;D
« Reply #9 on: February 21, 2013, 11:28:48 pm »
Short rod noise
Offline suzuki27
« Reply #10 on: February 22, 2013, 11:54:01 am »
I've had acouple of PE's over the years and they all had more rattles than a millionaires baby- boom tish.
You can check the lower engine mounts as the bolt is smaller than the hole in the cases and this can cause excessive vibration- you fit the next size up bolt after drilling the case hole to match etc.
« Reply #11 on: February 22, 2013, 01:53:53 pm »
Silence is the worst sound a bike can make.
Just ask Dangerous Dave after his CanAm quite suddenly started making a very loud silent noise at Ballan the other day!
Offline Canam370
« Reply #12 on: February 22, 2013, 03:12:56 pm »
I didn't hear his bike not running?! It must have been all the noise Dave was suddenly making to cover the bikes silence!
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #13 on: February 23, 2013, 02:24:59 pm »
The BIG end can make a heck of a noise if it is shot. My PE175N dropped about 12db on the meter after I did the big end.
Tony T
« Reply #14 on: February 23, 2013, 06:40:19 pm »
I doubt that's a problem, Luke.
The previous owner had it all apart and checked it all out an I had quick check when I fitted a fresh piston.
All seems good, so I'm confident that it's nothing out of the ordinary.
Thanks for the input.
