Author Topic: Is this to much  (Read 13586 times)
Offline flyingdg
Is this to much
« on: February 19, 2013, 11:39:16 am »
http://s751.beta.photobucket.com/user/flyingdg/media/polishedtrans002.jpg.html#/user/flyingdg/media/polishedtrans002.jpg.html?&_suid=1361233177727003489972057214086
Is this to much? Had a maico transmission and clutch polished like the big five factory teams are doing to there team race bikes. If it helps the trans shift better and last longer I think it will be worth it.
Offline EML
Re: Is this to much
« Reply #1 on: February 19, 2013, 11:50:03 am »
If it does all that and should also reduce drag-so why not?
Re: Is this to much
« Reply #2 on: February 19, 2013, 12:02:12 pm »
In this case function follows form! Who cares if it shifts better it looks outstanding. J
Re: Is this to much
« Reply #3 on: February 19, 2013, 12:30:13 pm »
It's pretty common amongst road racers.....it does work....they change gear like a hot knife through butter.
Offline flyingdg
Re: Is this to much
« Reply #4 on: February 19, 2013, 01:13:07 pm »
I think your right Jerry… does look good. I heard that the shifting is great. I would hand polish all the clutch parts for a easy pull, I could never do this good by hand. I’m going to build a new motor with the cut down cases with all the polished parts and the reed top end.
Offline 09.0
Re: Is this to much
« Reply #5 on: February 19, 2013, 01:48:44 pm »
You will have to put a Perspex window in the cases so you can see them!
Re: Is this to much
« Reply #6 on: February 19, 2013, 01:55:41 pm »
The other day I was picking up some bling from my polisher and sitting on his bench was a Kawasaki 1000 transmission in pieces, all polished up and shiny as a new pin that he'd done for the bike shop next door to him for a historic superbike they're building for a customer. I might do a Maico trans myself and see what the difference is......
WARNING: THREAD DEVIATION.
Doug, as a separate issue, have you tried the coil spring conversion on a Maico clutch? I'm about to set up a magnum clutch for my 360 oval and want to try the Wheelsmith coil conversion I've had for yonks.
Offline KTMaico
  • "Love or Lust it's always a Maico"
    • Maico Lovers & Fans
Re: Is this to much
« Reply #7 on: February 19, 2013, 03:36:55 pm »
I thought that Carbon and Dry Film coatings were the go for transmission gears and bearing?
Kevin
1981 Maico 490 (Special Build)
1979 Husqvarna CR250
1975 Suzuki RH250
1975 Suzuki RM125 S
1959 Mk1 Jaguar 3.4 4 speed manual with O/Drive
Offline flyingdg
Re: Is this to much
« Reply #8 on: February 19, 2013, 04:02:35 pm »
Mark... I have never used the spring but Jeff Mullins at maico werks likes the spring. I think if you have the preload set right it would work good I had all the Belleville springs polished so there is no friction, I would hand polish all the springs on some of the clutches I have done and it helps Jeff does this polishing as a service at his shop now. It is called isotropic polishing.
Offline EML
Re: Is this to much
« Reply #9 on: February 19, 2013, 04:19:12 pm »
So do Maicos normally have a leaf sprung clutch instead of coils--that's a bit old fashioned  :D
Re: Is this to much
« Reply #10 on: February 19, 2013, 04:36:09 pm »
No wonder you need training wheels on your bike ya cheeky prick ;D.
Offline Zakk
  • rAdelaide
Re: Is this to much
« Reply #11 on: February 19, 2013, 10:44:03 pm »
polishing the gears and shafts will remove any surface inperfections, plus expose any small cracks or chips. also as said, oil wont cling as well to a polished surface so there'll be a smaller % HP loss due to drag.
oh, and plus it looks better too  ;) i remember seeing a clear window clutchcover kit for early GSXR's to give the bike that 'dry clutch look'...
Offline ola_martin
Re: Is this to much
« Reply #12 on: February 19, 2013, 11:26:49 pm »
Wouldn't say so, 2013 1/2 KTM SXF:
A special Ryan Dungey-developed 280 psi Belleville washer will come stock in the Factory Edition.
Offline flyingdg
Re: Is this to much
« Reply #13 on: February 20, 2013, 03:48:01 am »
So maico was ahead of there time?
Re: Is this to much
« Reply #14 on: February 20, 2013, 10:38:51 am »
Does anyone know of a company that does Isotropic polishing here in Oz?
http://www.bvproducts.com.au/superfinishing
