CZ
CZ 400 74 model pivot pin removal
Topic: CZ 400 74 model pivot pin removal (Read 2981 times)
VMX Andrew
February 15, 2013, 05:27:23 pm »
Having heaps of trouble with this little sucker.
Any hints or tips much appreciated.
Regards
Andrew.
tony27
Re: CZ 400 74 model pivot pin removal
February 15, 2013, 07:08:44 pm »
It will be rusted to the rear engine mount, get the engine out & try heating the engine mount where it goes through a few times.
You should be able to remove the swingarm & mount in 1 piece which should make things easier
New pins & bush assemblies are easy to get, advertised on ebay quite often
http://www.ebay.com/itm/cz-motocross-falta-125-250-360-380-400-NEW-SWINGARM-AXLE-/200893477575?hash=item2ec62f32c7&item=200893477575&pt=Motorcycles_Parts_Accessories&vxp=mtr
Never had this problem myself but it's not an uncommon problem, someone will no doubt reply later on that has been through doing this
Husabergpete
February 21, 2013, 09:15:08 pm »
Have had a similar problem with Huskies - our CZ was no issue. But tipping it on the side and spraying penatrine in on a daily basis for a week or so will help then as mentioned add heat and steady as she goes. All the best Pete
KTM 250 1980, Maico 250 AW 1977, Husqvarna CR 430 1981, , CZ 250 1973 and a 550 Husaberg
CZ
