Author Topic: Mikuni 40 on 81 490?  (Read 2998 times)
Offline ola_martin
« on: February 12, 2013, 12:12:23 am »
Hello.
I have a 81 490 minus the carb.
I don't have a 38, but I have a couple of good 40mm VM's, has anyone tried, and does it work?
Offline ola_martin
Re: Mikuni 40 on 81 490?
« Reply #1 on: February 12, 2013, 12:31:16 am »
Or what about a modern PWK flatslide 38??
« Reply #2 on: February 12, 2013, 09:35:53 am »
The 40 (Bing I presume) would work fine on the 490 Martin. As far as the PWK flatslide, it'd no doubt work well but the racing legality depends on your country's rules. It's not legal for Evo here in Oz.
Offline paul
« Reply #3 on: February 12, 2013, 02:03:10 pm »
you can buy new bings from wulfsports all ready set up for a 490
Offline KTMaico
  • "Love or Lust it's always a Maico"
    • Maico Lovers & Fans
« Reply #4 on: February 12, 2013, 05:29:04 pm »
Ola,
       Go with the Bing, maybe the later 1983 Maico 490 Bing with choke and tickler and set it up the piston port 81-82.
http://ausvmx.ning.com/group/kevintomkyns/forum/topics/bing-54-rebuild
Kevin
« Last Edit: February 12, 2013, 05:36:23 pm by KTMaico »
1981 Maico 490 (Special Build)
1979 Husqvarna CR250
1975 Suzuki RH250
1975 Suzuki RM125 S
1959 Mk1 Jaguar 3.4 4 speed manual with O/Drive
Offline ola_martin
« Reply #5 on: February 12, 2013, 07:08:49 pm »
Thanks.
I don't have a Bing, only 36mm anyway. So the 40 I asked about was the Mikuni VM roundslide.
And the reason I asked about the Keihin PWK 38, is that I can get a new one super cheap (under half of a Bing), and it wouldn't be illegal here, so if that works well I'll go for that?
Offline holeshot buddy
  • sunshine coast qld
« Reply #6 on: February 12, 2013, 11:35:46 pm »
those 40mm roundslide mikunis are great carbs
i run them on my kx500s and my big bore rm500
i took a pwk 38mm off to try this carb and the improvement was great
easy to start and good power spread through the rev range
do it ;D ;D ;)
follow me to first turn
