Author Topic: RM 465 RM 500 conrods  (Read 7934 times)
TM BILL
« on: February 08, 2013, 02:09:35 pm »
Would anybody have an RM 465 and an RM 500 rod they could measure for me
I have a NOS rod i thought was for an RM 400 but its not  ::)
I have feeling its RM 465 or RM 500 but would like to measure it against a known rod
Only marks on the rod are S7  ???
Offline Ktm181
Re: RM 465 RM 500 conrods
« Reply #1 on: February 08, 2013, 02:35:41 pm »
Hi mate, i should be able to get to my shed and measure both for you over the weekend if that will help, i'll measure centres, bore size and width but only have a digital vernier to do it.
Kt
TM BILL
« Reply #2 on: February 08, 2013, 02:43:59 pm »
Thanks that would be much appreciated  :)
Bill
« Reply #3 on: February 08, 2013, 08:36:09 pm »
We borrowed out our last conrod for measurement and never got it back  :'(
this is what was asked of us at our last investigations.
Please keep us in the loop for a few of these much needed items Bill.
cheers A&S
Quote:If any comment please feel free to contact us.
Regards.
José Marin. F.SAMARIN CO.LTD.
Thank you for their interest in our products.
We don't have the measures of the connecting rod that you us consultation of
Suzuki RM 500.
Do you have the measures?
A (longitude center to center) =
B (small extreme interior diameter) =
C (big extreme interior diameter) =
D (width big and small end) =
F (diameter pin crankshaft) =
L (longitude pin crankshaft) =
Piston bearing =
Crank bearing =
Washers =
Offline seego
« Reply #4 on: February 08, 2013, 08:37:08 pm »
Hi if it is a rm500 rod it will have the numbers 1422 cast onto it and a rm465 will have the numbers 1421 cast onto it.
Offline mick25
  • Hunter valley NSW
« Reply #5 on: February 08, 2013, 08:41:13 pm »
your  FAT BOY HARLEY is nice bazz ;) sounds sweet one of my fav harleys
« Last Edit: February 08, 2013, 08:43:43 pm by mick25 »
« Reply #6 on: February 09, 2013, 01:24:00 pm »
cheers A&S
Regards.
Suzuki RM 500.
Piston bearing =
Crank bearing =
Washers =
Samarin do great products, price will be around 140-160 Euro for the complete kit(they are all around that price)
« Reply #7 on: February 09, 2013, 01:32:45 pm »
very true,but we dont have the rod to do the measurements  :'(
« Reply #8 on: February 09, 2013, 05:06:55 pm »
465 =
A  =    136 mm   centres
B  =    S/E ID 23mm
C  =    B/E ID 31mm
D  =  B/E width   21.90mm       S/E width   22.00mm
Offline Ktm181
« Reply #9 on: February 09, 2013, 08:06:01 pm »
Ok, new genuine rods both still in Suzuki packets..all measured with digital vernier.
465 rod marked 1421 on side.
Centre to centre 136.2mm
Little end i.d. 23mm
Big end i.d. 31mm
Width of b.e. & l.e. both same at 21.85mm
B.E. pin 25 o.d. & lenght of 69.9mm
B.E. bearing i.d. 25.2mm and 21.75 width. Cage itself, not roller i.d. if that makes sense.
500 rod marked 1422 on side
Centre to Centre 136.26mm
L.E. 23MM i.d.
B.E. 32.9MM i.d.
width L.E 21.9mm
width B.E. 24mm (wider than l.e.)
Big end pin 26mm x 69.9mm
b.e. bearing cage i.d. 26.9mm and width of cage at 23.7mm
Hope this helps. I dont have thrust washers for either to measure (nla) and dont have little end bearings as yet.
Kt.
Offline rmbing68
« Reply #10 on: February 11, 2013, 03:48:48 am »
Would you happen to have the dimensions for a '79/'80 RM 400 rod? Thanks, Ralph.
TM BILL
« Reply #11 on: February 11, 2013, 05:58:51 am »
Thanks for that  :) i will measure up and see if its a match  :)
TM BILL
« Reply #12 on: February 13, 2013, 03:19:37 pm »
Thankyou all for the help  :) well its not an RM 400 , 465 or 500  ???
I will start a new thread with its dimensions and see if anyone recognises it  :)
