Author Topic: Honda XL 23" Wheel Conversion to 21"  (Read 11095 times)
Re: Honda XL 23" Wheel Conversion to 21"
« Reply #15 on: February 04, 2013, 09:43:04 pm »
all good then when its ready
slides
were is the 19in wheel form my flattracker
jim
Offline smed
« Reply #16 on: February 04, 2013, 09:51:25 pm »
That helps me too SMed, as i am looking to replace the 23 on my RZ. I knew there were some XR that would fit it, but was not sure.
Brett
No worries guys,I use the powersportspro site quite a bit for cross referencing,If you go to the main site look up oem parts for your brand find the part # & then type the number into the parts search then click on select model :)
« Reply #17 on: February 21, 2013, 05:53:25 pm »
I hate looking up info on the net, some of those sites take forever to load if you have a slow connection.
HTH...
Part # = 44601-430-000
Part Description = HUB, FRONT WHEEL
Model Count = 12
CR125R-A 1980 125 CR125R Off Road
CR125R-B 1981 125 CR125R Off Road
CR125R-Z 1979 125 CR125R Off Road
CR250R 1978 250 CR250R Off Road
CR250R-A 1980 250 CR250R Off Road
CR250R-Z 1979 250 CR250R Off Road
XL250S 1978 250 XL250S Dual Sport
XL250S-A 1980 250 XL250S Dual Sport
XL250S-B 1981 250 XL250S Dual Sport
XL250S-Z 1979 250 XL250S Dual Sport
XR250-A 1980 250 XR250 Off Road
XR250-Z 1979 250 XR250 Off Road
Couldn't work out what Honda call a backing plate to look it up
Tony T
« Reply #18 on: February 21, 2013, 08:45:49 pm »
Thanks Geoff.
I think the XL250S is probably the only one with that type of backing plate because the lug on the fork leg and the groove in the backing plate are horizontal. All others are vertical.
Regardless, I bit the bullet and got the correct front end for it with help from TT5Matt.
It looks much better now.  ;)
