Author Topic: YZ125C bitsa could be a good investment?  (Read 3227 times)
Offline mick25
  • Hunter valley NSW
Re: YZ125C bitsa could be a good investment?
« Reply #1 on: January 30, 2013, 07:25:31 pm »
Thats cheap as chips ,the tank is worth $200 bucks to a HL lover
« Reply #2 on: January 30, 2013, 07:31:14 pm »
That sale is just for a swing arm isn't it?
Offline mick25
  • Hunter valley NSW
« Reply #3 on: January 30, 2013, 07:33:19 pm »
You are right mainline I jumped the gate there ;D I should of looked at the add  better :P
« Last Edit: January 30, 2013, 07:35:08 pm by mick25 »
Offline oldyzman
  • 250 two stroke!
« Reply #4 on: January 30, 2013, 07:52:19 pm »
The swing arm looks like it could make a good anchor for a 12ft tinny.
« Reply #5 on: January 30, 2013, 07:59:18 pm »
The tank & head is sold but the rest is still available, if it was ridden by someone fast, the cylinder could have some magic in it?
« Reply #6 on: January 30, 2013, 08:24:35 pm »
The extended swing arm doesn't achieve anything more than a stock YZ-X swing arm does, unless you count "look bad" as an attribute...
And I don't think it looks like a pro job either.
Offline KB171
« Reply #7 on: January 30, 2013, 08:52:52 pm »
    A fine bit of Metal Work, multi axle locations ;)
Offline mustanggrahame
« Reply #8 on: January 30, 2013, 09:03:10 pm »
Just horrible. It takes a certain type of person to try and turn a negative into a financial positive. Good luck to him.
Cheers, Grahame
« Reply #9 on: January 30, 2013, 09:53:32 pm »
Shit welding....looks like a bit of slag inclusion.
Offline steveo247
« Reply #10 on: January 30, 2013, 10:20:03 pm »
I messaged the guy to see if he had any other 'trick' stuff.
he swears that swingarm must have been a factory rider, called me crazy for not wanting it.
Offline Rookie#1
  • JUST SHUDDUP AND RIDE IT!!!
« Reply #11 on: January 30, 2013, 11:04:49 pm »
Yeah a factory rider, maybe for Malvern Star!!
 :D :D :D :D :D :D :D :D :D :D :D
Offline oldyzman
  • 250 two stroke!
« Reply #12 on: January 31, 2013, 10:56:58 pm »
Yep. Noted all of that about the swing anchor, still think you could hot dip gal the thing and it could then be useful for the 12ft tinny. What a toss.
