Author Topic: preping fo new chrome.  (Read 3318 times)
Offline asasin
« on: January 29, 2013, 02:12:12 pm »
Hi I need to get a tank chromed, it has lots of surface rust on it as well as old chrome and some paint.  how far do you go in preping it before sending in?
I was thinking of getting it dipped stripped but was afraid of it being too harsh.
If in doubt ,WIND IT OUT
Offline mick25
  • Hunter valley NSW
Re: preping fo new chrome.
« Reply #1 on: January 29, 2013, 03:06:15 pm »
Bead blasting may do the job, its very fine and will get rid of any rust but the chromers may know the best way I would ask them.
The chromers may have there own bead blaster or soda blasters and do it for you. ;)
« Reply #2 on: February 03, 2013, 09:17:57 am »
What are you doing now....if it doesnt go chrome it?......have you got rid of those horses yet?
Offline Canam370
« Reply #3 on: February 03, 2013, 09:45:14 am »
The platers will put the tank into a bath to remove all of the old plating anyway so a rough tidy will be OK. Any serious pitting will require extra copper and nickel to fill the pits before the final chrome finish. Be specific regarding the quality of the finish that you want - its better to pay for extra polishing at the prep stage and get a nicer final job than paying less for a pox result and then grizzle about it.
Offline asasin
« Reply #4 on: February 03, 2013, 06:10:20 pm »
Thanks Can am great advice
Davey me old mate you obviously didn't float away , hope you are ok.Been car racing all day with the daughter in the march, trying to convince her to give up the horses , perhaps i could chrome them ;D
Offline flower pot racing
« Reply #5 on: February 03, 2013, 07:52:16 pm »
There are no short cuts with plating.  Any imperferction will show.  If you skimp on the prep work you will be dissapointed with the end result.  They will polish out the rough parts to remove imperfections then they (should) tripple plate, ie copper, nickle then chrome.  Copper can be laid on thick and then polished to givethebest possible surfec forthe next layer.  Polish again after the nickle, then chrome.
If the tank is rusty, you may want to look for a one in better condition to start with it will be cheaper in the long run.
If the tank is rusty any way, by the time the damage / rust is polished off the metal will be getting very thin....
Go to a good plater who will tell you all of this anyway.
And it is going to cost you as well.......  plating isnt cheap (not in the UK anyway)
Offline asasin
« Reply #6 on: February 04, 2013, 05:23:30 am »
thanks  flower pot, problem is it is a 1933 bsa so tanks a little scarce. the good thing is they were made of real metal  ;D so plenty thick enough to clean up . I will get as good as possible , i have a glass bead blaster so will start there.
« Reply #7 on: February 04, 2013, 07:53:23 am »
Plating is getting dearer all the time here too.
Don’t be blasting anything your going to chrome, it just makes more work for the polisher and makes the metal that bit thinner.
The platers know how to remove plating, the do it often, then use their polisher or find you own.
