Author Topic: YZ G andH rear springs  (Read 8076 times)
Offline motomaniac
« on: January 28, 2013, 05:57:39 pm »
Anyone got the colour codes for YZ G and H models springs? I'm looking for a heavier spring for a 125 G apparently a 250 G spring is the go
maico police
Re: YZ G andH rear springs
« Reply #1 on: January 28, 2013, 06:04:15 pm »
There's about three different G/H 250, 465 springs (I think) Brent and I've got a few different ones but don't know what's what. I should have my spring tester in few weeks time so I'll measure them up and let you know what I have if you're still looking by then.
Yes the standard 125 is a little soft for anyone over the weight of a six week old kitten.... :-\
maico police
« Reply #2 on: January 28, 2013, 06:19:23 pm »
Yes I do. Too heavy for me. Ideal for a heavier rider I'd say. Duel rate as well.
Offline motomaniac
« Reply #3 on: January 28, 2013, 06:44:39 pm »
thanks Ross , Im in the same boat , have a few yz/it shocks and springs but am unsure of the rates.
What rate are your's Walter ?
Offline Zakk
  • rAdelaide
« Reply #4 on: January 28, 2013, 08:15:43 pm »
2.5kg - yellow/red
2.7kg - yellow/purple
2.9kg - yellow/pink
3.1kg - yellow/white , but i've seen this colour listed as a 3.5kg in some publications
i've got a YZ490J shock and it has a 4.5kg spring, which i think is the heaviest for that series, and the spring will fit on an earlier mono-shocks ... but can't remember the colours at the moment.
*edit*..
4.5kg - white/blue .. i had a look  :)
« Last Edit: January 28, 2013, 08:27:06 pm by Zakk »
maico police
« Reply #5 on: January 28, 2013, 08:29:42 pm »
The J springs are single rate and not ideal for the mono-shocks.
Offline Zakk
  • rAdelaide
« Reply #6 on: January 28, 2013, 09:09:11 pm »
those colours are from a monoshock H/J's  manual. the 3.1kg yellow/white spring is listed as both the heaviest mono-shock IT J and the lightest mono-x YZ J
Offline Zakk
  • rAdelaide
« Reply #7 on: January 28, 2013, 09:21:58 pm »
i thought you told everyone that you were the guru.. ?
yes they're the same
maico police
« Reply #8 on: January 28, 2013, 09:28:37 pm »
Sorry. I thought you meant YZ J which had the linkage rear. Yes the IT J was still the mono-shock and had the variable rate springs.  :)
Offline Zakk
  • rAdelaide
« Reply #9 on: January 28, 2013, 09:52:19 pm »
the YZ J uses the same 3.1kg yellow/white spring as the IT J.
maico police
« Reply #10 on: January 28, 2013, 10:00:09 pm »
Well then, the YZ J spring (off the linkage rear end) has a single rate spring which is not really suitable for the mono-shock rear end. I don't know why the IT mono-shock (J) would have had a straight rate spring.  ???
Offline motomaniac
« Reply #11 on: January 28, 2013, 10:43:30 pm »
Yer doesn't make sense! I have a 490 J shock and it is single rate and has yellow white paint.
I wouldn't use it on a G/H  model .
I have a parts fiche CD that is incomplete , no 1980?? bloody hell .125 H red/green is soft , red/blue id hard but give sno rates.
YZ250G/H they show the same part# but no colours or rates .
YZ465 G/H green is soft but no rate , blue is hard but no rate given.
also IT465 soft is yellow /purple and hard is yellow white like ZAKK  said.
The other problem is the standard springs are not coloured?? is this right ?? at least the ones Im looking at now aren't.
« Last Edit: January 28, 2013, 11:28:04 pm by motomaniac »
« Reply #12 on: January 28, 2013, 11:19:09 pm »
The 250 / 490 J has these listings but my notes don’t give specs for the G / H models
5X5-22212-10-00 SPRING (K=3.25)  (HARD) U. R. ALT. PART (WHITE/GREEN)
5X5-22212-00-00 SPRING (K=3.5)  WHITE/YELLOW
5X6-22212-00-00 SPRING (K=3.75)  HARD (WHITE/BLUE) ALTERNATE PART
5X6-23141-10-00 SPRING, FRONT FORK (K=0.275)  SOFT
USE SPACER 5X6- ALTERNATE PART
5X6-23141-L0-00 SPRING, FRONT FORK (K=0.305) 2
5X6-23141-20-00 SPRING, FRONT FORK (K=0.325)  HARD
YZ 250 F is listed as...
90501-99480-00 SPRING,COMPRESSION (K=2.96 K=5.05 KG/MM)
HARD (PAINTED RED) ALTERNATE PART
90501-99479-00 SPRING,COMPRESSION (K1=2.55 K2=5.03 KG/MM)
HARD (PAINTED BLUE) ALTERNATE PARTS
90501-99481-00 SPRING,COMPRESSION STD (PAINTED YELLOW)
2X4-23141-10-00 SPRING,FRONT FORK (K=0.214KG/MM) SOFT
(USE SPACER W4-23118- LO WITH SET)
2X4-23141-L0-00 SPRING,FRONT FORK (K=0.268KG/MM)
2X4-23141-20-00 SPRING,FRONT FORK (K=0.333KG/MM) HARD
(USE SPCR. W4-23118- LO WITH SET)
Offline motomaniac
« Reply #13 on: January 29, 2013, 09:29:52 am »
Thanks Geoff.
