Author Topic: Replacement ignition coils  (Read 2803 times)
Offline ninjamk
« on: January 22, 2013, 02:15:35 pm »
I am look at replacing the ignition coils for both my ts250 and rv125.  Does anyone know of any good aftermarket ones with replaceable wires that work, or is it best to find a OEM NOS set?  After searching around I see a few 6v coils out there but dont know if they are compatible or not.  Thanks
Bikes: 1972 TS/TM250, 2007 KLX300, 2016 GSX-S1000
Re: Replacement ignition coils
« Reply #1 on: January 22, 2013, 09:47:15 pm »
the rv uses a magnito coil and the ts a cdi coil,ive seen a briggs and straton maggie coil on a rv and it worked fine.a victa coil would work as well.as for the ts250 any bike that uses a cdi system can be a coil donner.both bikes have 6 volt SEPERATE charging system for the battery to run blinkers/horn/taillight and brake lights only but nothing to do with ignitions,skools over ;D
Offline ninjamk
« Reply #3 on: January 23, 2013, 03:04:34 am »
Thanks guys.  I was looking at this one:
http://www.ebay.com/itm/2102-0029-Emgo-Universal-Ignition-Coil-6-12-volt-works-points-C-D-I-/170927082378?hash=item27cc0c4b8a&item=170927082378&pt=Motorcycles_Parts_Accessories&vxp=mtr
Its pretty cheap so im a little worried about it being junk.  Are there any other bikes that have coils that would be compatible?  I think its silly that Suzuki used coils with non replaceable wires.
Offline odd1
« Reply #4 on: January 23, 2013, 05:55:46 am »
I don't think they where expecting to still have there bikes around 30 years later!
« Reply #5 on: January 23, 2013, 11:25:05 am »
since cdi ststems work on 100 plus volts it will be over driving the coil causeing early failure,even ballest coils on cars fail if not used with the 3volt dropping ballast.best to get the right coil for the system its  using eg cdi or magnito ignition and have trouble free biking,there around and on ebay
