Author Topic: oil height  (Read 2141 times)
Offline Ekka
  • Go hard or go home
oil height
« on: January 20, 2013, 06:11:25 pm »
G,day need help with me wr 250 72 mod on fork oil level cheers ek
Offline Viper666
    • Ballarat Rovers MCC
Re: oil height
« Reply #1 on: January 20, 2013, 06:33:43 pm »
72 WR? ? ? ? ?
Offline Ekka
Re: oil height
« Reply #2 on: January 21, 2013, 06:36:49 pm »
R a wr husky 250 1972 model
Offline euro bikes
Re: oil height
« Reply #3 on: January 22, 2013, 11:54:55 am »
Should be 200ml each leg.  SAE 20W-SAE 50W that is what the husky book says.
« Last Edit: January 22, 2013, 08:33:56 pm by euro bikes »
Offline PEZBerq
  • Brisbane
Re: oil height
« Reply #4 on: January 22, 2013, 11:25:50 pm »
Why dont you play with the oil level and see what difference it makes to the forks initial plushness. Lower the level the more air and the more springy the air column. The higher the level the less air column and the initial travel will be harsher. Or that's the theory anyway  ;D ;D
Start with the 200 ml per leg advice and go up or down from there.
Damping is a function of oil viscosity and speed of fork movement. Can be adjusted by changing oil weight. if you want a better more modern damping action action however then fit a cartridge emulator kit such as Race Tech Gold Valves  or YSS PD valve kit.
Of course if your weight is wrong for the fork springs then you will never be happy  ::)
Good luck.
