Author Topic: Wanted 1984 Honda CR Disc Brake Forks  (Read 3213 times)
Offline SON
« on: January 20, 2013, 09:35:28 am »
Any condition, even just sliders
2 sets needed,
Offline PCMAX
Re: Wanted 1984 Honda CR Disc Brake Forks
« Reply #1 on: January 20, 2013, 11:40:54 am »
PM sent
Offline VMX Andrew
« Reply #2 on: January 20, 2013, 12:47:37 pm »
I have a set of 85 model forks and a whole wheel with the disk sitting
in the shed collecting dust and cobwebs if you are interested.
Andrew
Offline SON
« Reply #3 on: January 20, 2013, 04:05:01 pm »
I am after the 84 Disc Setup Pre 85 Legal, are the 85 legs the same as 84??
Offline crs-and-rms
  • heaven 23
« Reply #4 on: January 20, 2013, 05:32:13 pm »
im sure the  84 and 85 legs are the same the  85 disk rotor has a different hole patern .the brake calipers are the same  ,the master cylinder is the same i have the parts book some where i could check the part numbers for you
Offline SON
« Reply #5 on: January 20, 2013, 05:46:11 pm »
Thank you
Offline crs-and-rms
  • heaven 23
« Reply #6 on: January 20, 2013, 07:10:31 pm »
just checked the part numbers the only differance in the part numbers is the  the model number the rest of the part number is the same there is one differance on the fork tube the 84 is the same diameter where it goes through the tripple clamps the 85 model has a smaller diameter in between the top and bottom clamp
Offline SON
« Reply #7 on: January 20, 2013, 07:26:35 pm »
There is 20 sets on US Evilbay but I always want to buy local first,
I want legal disc brakes for a 1984 RM this appears to be the way
Offline crs-and-rms
  • heaven 23
« Reply #8 on: January 22, 2013, 06:33:45 pm »
any luck finding those forks son
« Reply #9 on: January 22, 2013, 07:09:13 pm »
I think I've got a spare pair. Let me have a look and I'll get back to you.
Best pre-85 legal brake for sure (ie: better than the KX disc).
Offline SON
« Reply #10 on: January 22, 2013, 07:57:34 pm »
Thank you, I am happy with just the sliders and caliper,
84 TS250X wheel and disc should be Pre 85 Legal??
Offline crs-and-rms
  • heaven 23
« Reply #11 on: January 28, 2013, 09:31:32 pm »
how did you go with the forks son find any here in oz ?
Offline SON
« Reply #12 on: January 28, 2013, 09:45:02 pm »
no not yet,
I will give it a few more days,
Offline crs-and-rms
  • heaven 23
« Reply #13 on: February 03, 2013, 03:58:47 pm »
any luck with the forks yet
Simo63
« Reply #14 on: February 03, 2013, 08:51:32 pm »
I have a set of1984 CR250 RE front forks.  Currently dismantled but complete from memory.
Location Sunshine Coast Qld.
