Author Topic: Huge CZ shed clean out  (Read 4400 times)
Offline HL400
« on: January 19, 2013, 08:04:28 pm »
Huge CZ shed clean out sold as a job lot,  CZ 380 Parts  I have goon all Husky so these parts have to go.
 2 – CZ 380 new piston kits 82.75mm
1   CZ 380 new piston kit 82mm
1 new set 82.50 Rings
1-new base gasket
1-new head gasket
2 new 13t front sprockets
1 –new 14t front sprocket
1 new 52t rear sprocket
1 new gear lever Falta copy
1 new kick starter spring
assorted lock tabs and bolts
1 clutch spring removing tool
1 clutch hub holding tool
1 flywheel puller
1 clutch nut tool
4 set new 35mm fork seals
1 cylinder. (needs a rebore)
1  complete fly wheel and point set (used)
1 air box with no dents
and assorted used bits and pieces.
$500.00 for the lot. ONO
Offline VMX60
Re: Huge CZ shed clean out
« Reply #1 on: January 20, 2013, 03:11:58 pm »
Where are you located and is the barrel 5 stud or 6 stud
Offline HL400
« Reply #2 on: January 20, 2013, 04:16:04 pm »
its a 6 stud and the current bore is 82.75 but will need a rebore as its has a deep gouge on one side.  HL
Offline VMX60
« Reply #3 on: January 20, 2013, 04:35:02 pm »
HL
Where are you what state ?
Offline paul
« Reply #4 on: January 20, 2013, 04:45:45 pm »
1-new base gasket
1-new head gasket
1 flywheel puller
1 clutch nut tool
that stuff would fit in a mid size box so hows it a huge shed clean out ;D
Offline HL400
« Reply #5 on: January 20, 2013, 05:01:43 pm »
I am In Victoria,  and OK Paul its a mid size but heavy sheed clean out ha ha   HL
Offline HL400
« Reply #6 on: January 22, 2013, 08:22:12 pm »
All sold     HL
