Author Topic: CZ porting for Mikuni Conversion  (Read 3417 times)
Offline Husabergpete
« on: January 19, 2013, 01:42:28 pm »
Boys,
We have a Mikuni conversion kit for our '73 that includes the aloy inlet manifold which is slightly wider in the ports than the original barrel.
Therefore there is s step of about 3mm between the manifold and the barrel. Is it necessary to enlarge the port all the way through to the steel cylinder liner ports or ok just to blend in the alloy section?
Many thanks and cheers beers
Pete
Re: CZ porting for Mikuni Conversion
« Reply #1 on: January 19, 2013, 02:26:24 pm »
Just taper the port to match, doesn't need to go right up to the liner but the shallower the taper the better.
Almost sounds like you've picked up a manifold for a 400 which was a fairly standard modification to allow the fitment of a 36mm mikuni
http://czmadness.net/techdata/GPC%20-%20Pg91.jpg
http://czmadness.net/techdata/GPC%20-%20Pg92.jpg
http://czmadness.net/techdata/GPC%20-%20Pg93.jpg
http://czmadness.net/techdata/GPC%20-%20Pg94.jpg
These pages come from the Grand Prix Cycles(Moto-x Fox) manual from around 73,74
Offline VMX60
« Reply #2 on: January 19, 2013, 07:48:11 pm »
Spot on Tony std mod to fit the 400 intake on to the 250 when fitting a Mikuni 34mm up to 38mm sizes
Good  CZ  hot tip
« Reply #3 on: January 19, 2013, 08:14:50 pm »
Too Right boys we have the 400 manifold which came with the carb kit.
We will taper it as good as possible and see how we go.
thanks a lot boys!
Carl
Did it last week - worked out very nice thanks
« Last Edit: March 06, 2013, 05:11:22 pm by Husabergpete »
