Author Topic: Oil for TM250  (Read 2786 times)
Offline ninjamk
Oil for TM250
« on: January 18, 2013, 05:09:52 pm »
Hi Guys,
What oil are you guys running in your TMs with the cci oil pump.  I consulted my manual and it says to run a self mixing sae 30 2t oil.  I was thinking of running Maxima Super M, but there are two types, the premix type which is sae 30, and the injector type which is sae20.  Would I be best off running the premix type, even though im using the pump, since its sae 30.  The book also recommended Castrol r30, but I though you were only supposed to premix bean oil..  Im probably over thinking this, but I dont like to gamble.
Bikes: 1972 TS/TM250, 2007 KLX300, 2016 GSX-S1000
Offline Toolboy
Re: Oil for TM250
« Reply #1 on: January 18, 2013, 06:12:31 pm »
I use Mobil 1 Racing 2T in my TM400
The spark plug is nice chocolate colour
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Re: Oil for TM250
« Reply #2 on: January 18, 2013, 06:43:34 pm »
The R30 is fine in your pump, just do not mix it with any mineral oil.
 Use mineral injector pump oil as recommended . Cheers and great to see you have the lube pump in operation! ;)
« Last Edit: January 21, 2013, 10:28:18 pm by Tim754 »
Offline ninjamk
Re: Oil for TM250
« Reply #3 on: January 19, 2013, 01:23:57 am »
I keep the pump for all my 2 strokes.  Every Suzuki that I have seen with a non working pump just needed to be primed.  So run oil specified for injector use, no matter what the viscosity is?
Thanks again.
Re: Oil for TM250
« Reply #4 on: January 21, 2013, 02:51:40 pm »
Pardon my naivety, what is 'pump specific oil'?  (and brands/names).  asking as just finishing resto of an early TS/TM250 for dirt track racing.
Re: Oil for TM250
« Reply #5 on: January 21, 2013, 08:28:35 pm »
Can run just about any 2T oil in a pump in our climate.
Offline Doc
Re: Oil for TM250
« Reply #6 on: January 21, 2013, 09:00:28 pm »
As Loz says most oils are fine..some specific ultra high performance 2 stroke oils such as the castor/synthetic blend Castrol A747 are not recommended for oil pumps and this is stated on the back of the bottles. If in doubt read the bottle ;)
