Marketplace
Wanted
RT360 aluminium flange/adaptor between carb and reed block
Topic: RT360 aluminium flange/adaptor between carb and reed block (Read 935 times)
Andrew L
January 18, 2013, 04:13:54 pm »
Im after an aluminium flange/adaptor that the carby bolts to and then bolts to the barrell sandwiching the reed block for an RT3 360. cheers Andrew
Iain Cameron
Re: RT360 aluminium flange/adaptor between carb and reed block
January 18, 2013, 07:36:47 pm »
Pm me Andrew
Marketplace
Wanted
