Author Topic: can anyone ID this pipe?  (Read 10974 times)
Offline ty4
« on: January 13, 2013, 02:58:24 pm »
EDC maybe ??   and no, rusty will not help  ;D
tony
hillsy_badboy
Re: can anyone ID this pipe?
« Reply #2 on: January 13, 2013, 03:44:26 pm »
Is "Bassani" too obvious?
« Reply #3 on: January 13, 2013, 03:59:35 pm »
Not Bassani Nathan they were never that angular plus it  is too far out from the rear sub frame . EDC I doubt it they were nice and tucked in to the frame as well .
« Reply #4 on: January 13, 2013, 04:02:48 pm »
Also its too low over the kick starter . I'd say its from something other than a yamaha and been bodgied to fit .
Offline ty4
« Reply #5 on: January 13, 2013, 04:04:57 pm »
can't tuck into the frame because they put a brace right where the pipe needs to go when they layed the shocks forward
« Reply #6 on: January 13, 2013, 04:48:01 pm »
Insert QuoteIs "Bassani" too obvious ?
I'm with Iain, I think it may be one of the Aussie made pipes that popped up everywhere in the early 70's. I forget most of the brands but Denco was one, Trail and Track loved 'em, called 'em Power Pipes whether they made power or not ;D. I've got something similar (but not identical) hidden away somewhere in the garden shed.
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #7 on: January 13, 2013, 05:01:09 pm »
The header section of that pipe looks very much like the standard Yammie
pipe to me. I'll suggest it's a home made special.
Looks orright to me...
"flat bickie"
Offline paul
« Reply #8 on: January 13, 2013, 06:22:05 pm »
eltham dirt bikes use to make pipes for early yamahas
« Reply #9 on: January 13, 2013, 08:45:55 pm »
What stops it being a Bassani that's either from a different bike, or compromised by the lay-down shock mod?
As best as I can see, the heat shield and general construction are very similar to the way Bassani made their pipes - maybe it is a "Bassani copy", but how do you pick it as not the real thing?
« Reply #10 on: January 13, 2013, 10:38:38 pm »
the pipe on this bike was an after market built in Vic it was a copy of the bassani though  check out the thickness of the mufler , Ive had a couple of them and the tail section was a lot thinner .
« Last Edit: January 13, 2013, 10:44:01 pm by iainyz »
Offline JC
« Reply #12 on: January 14, 2013, 10:41:55 am »
I'd say EDC mated to std Yam header. Looks like it has no centre-section (parallel-sided) which was one of the distinctive features of the EDC.
Has the same overall shape & construction as EDC too, but original EDC header was very diff, as per pipe on #10X (that whole pipe looks to me like EDC, but w slightly shorter heat shield).
But rear mount bracket has been relocated to attach to original top shock mount instead of that hole a few inches further back
« Reply #13 on: January 14, 2013, 10:48:22 am »
I reckon you're right on the moolah John. I was looking for a photo of an Eltham Dirt Centre power pipe before I made comment. All I'm sure of is that it's not a Bassani. Did John Burrows have something to do with EDC? If not it may be another pipe that he made/marketed.
Offline ty4
« Reply #14 on: January 14, 2013, 03:37:09 pm »
thanks for the replies fellas...time to try and loosen some rust ;D
