Author Topic: 36mm mikuni on a rt3  (Read 2046 times)
Offline Andrew L
« on: January 10, 2013, 03:34:04 pm »
Im sure somone on here has already tried a 36mm mikuni on their rt3 so I ask for a bit of wisdom from the guru's.  I have borrowed one of my fathers 36mm mikunis to try and thought id ask if it is worth the effort , I have made and fitted a different pipe, it now go's extremely well in the mid range into the upper range as well but I feel its a bit strangled up top now, any opinions accepted before I waiste time in the shed. Cheers Andrew
Offline JC
Re: 36mm mikuni on a rt3
« Reply #1 on: January 10, 2013, 05:27:04 pm »
Might need to raise the exhaust port a little too. They're very mild standard.
