Author Topic: Name this bike and its country of origin  (Read 4933 times)
« on: January 06, 2013, 12:27:21 pm »
Offline odd1
Re: Name this bike and its country of origin
« Reply #1 on: January 06, 2013, 12:56:37 pm »
Praga  Czech   republic. Comrade Drakie has a 2 stroke version sitting in his shed
« Reply #2 on: January 06, 2013, 01:02:46 pm »
looks like a Berg copy ?
« Reply #3 on: January 06, 2013, 02:34:05 pm »
Known as the CD 610
« Reply #4 on: January 06, 2013, 02:40:26 pm »
Odd 1's the winner, it's a Czech made Praga 610....sort of a Hsaberg/Husky copy.
Offline mustanggrahame
« Reply #5 on: January 06, 2013, 03:35:24 pm »
What year is it?
« Reply #6 on: January 06, 2013, 05:18:48 pm »
probably 2000 by styling.
Offline Andrew L
« Reply #7 on: January 06, 2013, 09:30:58 pm »
Haslebergs have issues, how good would a Czech copy of one be.
« Last Edit: January 06, 2013, 10:22:31 pm by mavman4200p »
Offline Rookie#1
  • JUST SHUDDUP AND RIDE IT!!!
« Reply #8 on: January 06, 2013, 10:42:20 pm »
Tut tut tut!!! "older" Hassleburgs have issues, my 2012 TE250 is absolute gem of a bike and hasn't put a foot wrong, I have let as many people as possible ride it just to see what they say and their opinions are almost always the same as mine. Quite possibly the best, sweetest, linear 2t 250 enduro bike I've ever ridden!!  ;D
Cheers, Brendan
« Reply #9 on: January 06, 2013, 10:52:41 pm »
Going by everything else made in Czechoslovakia it'd be as solid as an anvil and bulletproof.
« Last Edit: January 07, 2013, 06:56:14 pm by firko »
« Reply #10 on: January 07, 2013, 03:23:25 pm »
Wikipedia (aka Wonkypedia) Has a bit of History and some links on the Prada 2000>2003 motocycles. Shame they have ceased production as with Australia's current exchange rate Hmmmm.
« Reply #11 on: January 07, 2013, 05:44:45 pm »
Cheers, Brendan
That's because it's a KTM  ;D
« Reply #12 on: January 07, 2013, 07:24:57 pm »
I don't know. I think it is a bit of a pity that a modern Husaberg is just a blue KTM. They used to be better than KTM even if not as reliable. The world needs more variety not less.
Cheers, Grahame
« Reply #13 on: January 08, 2013, 12:11:59 pm »
That Praga looks nothing like a KTM, it's more early Husaberg than anything. Here's the link to the former Swedish importer. http://www.milansweden.se/praga-610-ed.html
        4-stroke, water-cooled frame perimeter of Cr-Mo steel tubes
        volume 609 cc rear fork dural
        bore x stroke 95 x 86 mm
        Maximum output  about 58 to rear suspension Öhlins rear wheel travel 320 mm
        max torque about 63 Nm front wheel 1.60 - 21 "
        ignition CDI
        carburetor Dell Orto PHM 40 with ac. pump
        front brake disc D = 260 mm, Brembo
        rear wheel 2.15 - 19 "
        transmission 5-speed rear brake disc D = 220 mm, Brembo
        starter foot with autom. decompressor,
        Fork KAYABA 46, stroke 315 mm
        dimensions wheelbase 1550 mm, seat height 980 mm,
        ground clearance of 336 mm,
        weight 109 kg, (stand 119 kg)
        tank capacity 11 liters
        lubrication pressure, circulating filter
        price  124 300,-CZK incl. VAT ($5800 US)
« Last Edit: January 08, 2013, 12:39:56 pm by firko »
