Author Topic: Rear sprocket bolt pattern and std ratio?  (Read 3359 times)
Offline Paul552
  • HEAVEN #552
« on: December 23, 2012, 09:35:21 pm »
Is the bolt pattern unique on the old yamahas or are they interchangeable ?
To many beers to go out and pull the rear off but after a few I have come to the conclusion that I should add a few teeth from 49 to 51.
Off to MCA in the morning so if anyone knows if they are interchangeable you will save me waking up early to pull it off :) ???
Can anyone let me know the std gearing? Is it 13:49 ?
« Last Edit: December 27, 2012, 10:20:19 pm by TFR »
Re: Rear sprocket bolt pattern interchangeability yz125d
« Reply #1 on: December 23, 2012, 10:08:28 pm »
Same pattern as twin shock DT250/360/400, YZ125A,X, E, F, IT125, IT175D/E/F, MX125/175 and all AT1/CT1/DT125/175.
However, only the IT125/175s and YZ125X~F have the right combination of 520 chain and 10mm mounting holes.
Early TS185 (and 125?) look the same but are different.
Offline Paul552
  • HEAVEN #552
« Reply #2 on: December 23, 2012, 11:28:26 pm »
Thanks Nathan
I think I better wake up early a take it off :)
Thanks for the heads up
Offline Paul552
  • HEAVEN #552
Re: Rear sprocket bolt pattern and std ratio?
« Reply #3 on: December 27, 2012, 10:21:08 pm »
Can anyone tell me the stock ratio????
Thanks in advance
« Reply #4 on: December 27, 2012, 11:03:40 pm »
for which Yamaha ?
« Reply #5 on: December 27, 2012, 11:04:44 pm »
Yz d and e where 51/12
Offline Paul552
  • HEAVEN #552
« Reply #6 on: December 28, 2012, 09:02:29 am »
Thanks Ian
Mine has 13 49 no wonder it feels long.
Thanks again
