Author Topic: Brand new clutch plates - free  (Read 1776 times)
« on: December 22, 2012, 06:10:17 pm »
Hey I have aquired a couple of sets of brand new clutch plates and am happy to give a few sets away if they can be used by someone, don't take any if you're just going to throw them in a draw, only take em if you can really use them.  I just used some of the fibre's in my 79 KX250, the steels didn't fit.  The plates were sent from Italy for use in the Benelli TRE900 roadbike.  The fibre's are stamped 'KA4' on one tang.
FIBRE PLATE
ID  116mm,
Contact OD 138.75mm,
Tang OD 149.75mm,
Tang width 13.75mm,
Plate thickness 3mm,
12 tangs.
STEEL PLATE
OD 137.75,
Friction ID 113.75mm,
ID from tip of fingers 106mm,
Plate thickness 2mm,
30 inner fingers.
« Last Edit: December 24, 2012, 12:27:04 pm by John Orchard »
Offline oldyzman
  • 250 two stroke!
Re: Brand new clutch plates - free
« Reply #1 on: December 22, 2012, 07:49:05 pm »
Mate i have an A4 which i will be running at penrith DT. Could i get some fibre paltes as i am sure it will come into use. I can send you a XPress post bag if you are not in sydney.
Cheers Brett
« Reply #2 on: December 22, 2012, 07:59:33 pm »
Cheers Brett
Cool, how many you want, 5 or 6 ?  I'll PM you my address.
Offline oldyzman
  • 250 two stroke!
« Reply #3 on: December 23, 2012, 09:34:12 am »
Thanks John, i will look up the manual to see how many it takes i guess 6.
Cheers Brett
« Reply #4 on: December 23, 2012, 10:17:40 am »
My parts list for the 250 A4 & A5 says 5 but mine has 6 in it and it seems to look ok.
« Reply #5 on: December 24, 2012, 12:27:41 pm »
I still have a couple of sets left.
