Author Topic: Wanted VMX mag #4 or copy of KX250 article.  (Read 5930 times)
Re: Wanted VMX mag #4 or copy of KX250 article.
« Reply #15 on: December 21, 2012, 04:48:05 pm »
Yes Bill I have the money to buy a KX now, what mechanically (other than the shocks) is the difference between the $4500 and $7250 bikes?
What bore is each of them on?  When was the big-end done in each of them?
I'll start checking on shipping from NZ now.
« Reply #16 on: December 21, 2012, 05:38:30 pm »
I think I have an extra #4. I shall have a look and get back to you.
Cheers pancho.
Thankyou Sir  :-)
Offline pancho
« Reply #17 on: December 21, 2012, 05:59:22 pm »
 Sorry John false alarm, no spare #4. (unless I put it somewhere else).
 I have a full set plus #48, #34,and #33.
 I bought the extras when I saw the covers and thought "I must have missed that one"
 Sorry to raise false hopes John.
Maybe I can get the article copied for you.
pancho.
TM BILL
« Reply #18 on: December 22, 2012, 03:34:24 pm »
Forks and shocks are the only real difference ,and an RM 400 front hub to suit the forks .  The dearer bike will have new nightmare plastics , new chain and sprockets and a new seat cover and new filter element. Also will replace piston, big end and mains on dearer bike so as its fresh .
I won the NZ Livewire champs EVO 250 class on the std one a couple of years ago , so it goes well  :)
If your checking on shipping i can strip and crate up if that helps .
As for oversizes i cant remember what size their on  ??? one is plated so std and the other has been sleeved and i think on .50 OS
« Last Edit: December 22, 2012, 03:44:22 pm by TM bill »
TM BILL
« Reply #19 on: December 22, 2012, 03:40:50 pm »
Bill couple of questions
Can one fit an A4 tank to an A5
I like that fox bike of yours apart from the suspension what else does it have?
Cheers Slake
Hey Mick i guess you could fit an A4 tank but it would bot fit without some minor frame mods . The A4 tank sits in traditional round rubbers and cups at the front where as the A5 bolts through the frame at the front .
Apart from the Fox bits bugger all really  :) different muffler and an RM 400 front hub to match the forks brake lug.
